Old 07-07-2007, 11:23 AM
shiney shiney is offline
Default Which Flare Tool ?
I'm getting near to the point where I will need a flare tool, any recommendations on which one to purchase, type, hints, tips etc.
Martin
Old 07-07-2007, 12:45 PM
jlfernan's Avatar
jlfernan jlfernan is offline
The Parker Rolo Flare tool from Cleaveland Tools. Used it alot works great.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 07-07-2007, 01:23 PM
TSwezey TSwezey is offline
Home Depot plumbing department has one. No leaks. Easy to get and pretty simple to use. But the other one looks more professional.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 07-07-2007, 01:31 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Be sure to get a 37 degree flare tool. I don't know about home plumbing, but automotive flare tools are 45 degrees. I have the parker flare tool as pictured above. Expensive, but works well.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 07-07-2007, 05:06 PM
panhandler1956's Avatar
I second this motion! Just got one and it works great!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 07-07-2007, 05:10 PM
szicree szicree is offline
I've never seen anything but 45 degree tools in Depot. What brand did you buy?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 07-07-2007, 05:12 PM
Mel's Avatar
Mel Mel is offline
I wasn't aware that Home Depot carried a 37 degree flaring tool. DO NOT USE A 45 DEGREE TOOL! It may not leak now, but it's days are numbered. It will not "seat" properly with an AN fitting.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-07-2007, 06:30 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Rol-Air also good
I used a borrowed Rolo-flare for most of the flares that I've done so far. When I bought one, I opt'd for the little more expensive Rol-Air Flaring tool. http://www.aircraftspruce.com/catalo...ringtools3.php Comparing the two, the Rol-Air is a little easier to use in tight spots. The big advantage I found is the ability to move the die to check the flare without removing the tube from the clamp block.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
