Old 07-07-2007, 07:36 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Oil Pressure Switch / Warning light ?
I'm installing a oil pressure warning light as a backup to my engine monitor. I've installed the light but I can not find an appropriate switch. The only oil pressure switch that I've found is for a Hobbs meter. The Hobbs switch is normally open, so it works the opposite of want I want for a low pressure warning.
Any suggestions on what switch / tranducer to use?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 07-07-2007, 07:41 AM
Ironflight's Avatar
VAF Moderator / Line Boy
My switch is a genuine quality AC Delco part from NAPA.....sorry, don't have the part number, but I remember it wasn't hard to pick out.....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-07-2007, 07:56 AM
N131RV N131RV is offline
Default Vans has one for sale
The one I use does double duty. It illuminates the light when pressure is low, and turns on the hobbs when pressure is present.
I know I got it from vans, probably as part of the FF kit, but I'm sure they sell it separately.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 07-07-2007, 09:35 AM
ptrotter ptrotter is offline
Van's has an oil pressure switch with a SPDT switch. I can be used for both the hobbs and the warning light. THe normally open contact goes to the hobbs and the normally closed contact goes to the warning light. The center is ground so you need +12V on the other side of the hobbs and light.
Paul Trotter
Sussex, NJ
RV-8 82080 Finish/FWF Kit
N801PT
Old 07-07-2007, 06:35 PM
Rick_A's Avatar
Default Thanks
Looks like 2 good options, NAPA or Van's. I was hoping that I would find one that switched the ground side which is exactly what the Van's one does.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 07-07-2007, 07:34 PM
N62XS N62XS is offline
Default Wuscar Race Stinks so here is the part from Vans
Oil pressure switch for activating Hour Meter and light
Part Number = IE SPDT PRES-15 SW
Price = $27.00
Hope it helps.
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 07-07-2007, 10:25 PM
tcrv7 tcrv7 is offline
www.speedwaymotors.com 20lb $15,95 p/n604-50600 Adj pressure$19,95 p/n60450604
Tom Casson
N806TC{resv}
[] tcrv7@yahoo.comCessna 120 N76137
