During my annual, I noticed there is some slight play in the control sticks when moved fore and aft. When I hold one stick and move the other side to side, there is zero play, which is what you would expect given the linkage between the two. But when I hold one stick static and move the other fore and aft there is about a 1/16 inch of free play between the two. Since the elevator is connected with a tensioned cable, I think the play is from the WD-1210 control column attachment to the control sticks (bushing, AN4 bolt) or the attachment of the control column to the floor structure brackets. It's slight and maybe has always been that way, maybe I just never noticed it before.
So...some help. Could some please check their stick play as well? If nothing else, it will confirm what my wife has always said - I'm just too anal about some things.
