AFP pump caution and some questions
I purchased my AFP electric fuel boost pump a little over 3 years ago. Before installing the top front skin on my RV-8, I decided to make sure the thing actually pumped fuel in addition to just turning on with the application of 12V. Turns out it didn't pump a darn thing. After talking with Don at AFP, I removed it from the airplane and tried to suck gas out of a can straight into the pump (bypassing the check valve and the return valve), but it still didn't work.
I sent it back, and they discovered that the pump had dried out after 3 years on the shelf. Once they re-moistened the innards, it worked just fine. I'm told they've subsequently solved this issue by selling new pumps with lubricant inside to prevent them from drying out during extended shelf time. However, if you bought your pump several years ago and haven't tried it, be sure to try to pump some gas with it before the final installation and loss of easy access. If you bought an earlier-model pump and it dried out, you may have to remove it and pour some gas through it to re-moisten.
Now for the questions...
1) Should I remove the fuel pressure line at the transducer and run the pump to get the air out of the line, similar to what people do with the oil pressure transducer line prior to the first engine start?
2) What is a typical GPH reading for fuel flow exiting the AFP pump when the exit line is just sticking into a gas can? I'm showing 50ish GPH with free flow into a can.
3) After reconnecing everything in the fuel system and pressurizing it with the mixture in idle-cutoff, I get 29 PSI with the AFP pump on. After turning it off, the pressure doesn't drop much at all -- like only down to 20 PSI after an hour of sitting there. Is that acceptable?
Thanks.
-Geoff
RV-8 (final ?? percent)
