Peter:
Ok, now I understand what is going on. One suggestion/possibility to try is when you go to finally assemble things, place a dab of proseal at each scew location in the plexi cs. Then install the screws just to the point where they start deforming the skirt and then back out a smidge.
This will support the skirt dimples. It sounds like you might have over-countersunk your holes in the canopy. The first logical concern with this fix is that you are not tightening those screws enough. Thing is, you are using locknuts here, and this is not a structural part. The proseal will frim up enough that if you want to you can go back and slightly torque the screws a tad after all has set up.
Perhaps you could try to duplicate the problem you have with your skirts on some scrap plexi and aluminum and try the above method out.
Hope this helps.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
