Old 01-17-2021, 07:04 PM
rileyspoon rileyspoon is offline
Default Tailcone Fairings w/o removing rudder/stabilator?
I've already attached my rudder and stabilator and all the antiservo hardware but it looks like the assembly instructions for the fairings requires all that to be removed. Has anyone done this step without removing the rudder and stabilator?
Old 01-18-2021, 07:23 AM
John-G John-G is offline
I'm pretty sure my initial marking of the tail cone fitting was done with the tail feathers off. Then at some point they were installed because I do remember doing the drilling for the nutplate screw and rivet holes with the tail feathers on.
Sixth photo in this blog post:
http://www.dogaviation.com/2015/06/p...for-final.html
Beginning with the third photo in this post:
http://www.dogaviation.com/2016/03/c...-resolved.html
Hope that helps .... happy building.
John
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 01-18-2021, 08:39 AM
GatorsR1's Avatar
GatorsR1 GatorsR1 is offline
Default read ahead or be darned
I remember being so happy when finished with Section 11 (all the tail & trim installed) - only to see the NOTE at the very start of Section 12:
Begin this section with the V-Stab, Rudder, Trim/Servo and Stabilator Assemblies
removed from the Tailcone Assembly.
So I did take them all back off to build the the tailcone fairing assembly.
It gets somewhat easier to re-install the stabilator after learning from a few sessions of trial & error.
Bob Costello
RV12 #120764
"if you read it, buy it" - support DR & VAF
Old 01-18-2021, 10:17 PM
DaveWelch DaveWelch is offline
Default Yes but not recommended
As I recall there is enough wprk to be done fitting and installing the tail feathers that you need good visibility into that area without the cowlings in the way. The reverse is true when you fit and fiddle with the cowlings. Doable but a pain with the stabilator in place. Might as well get good at removing and installing all of those items.
BTW, you have the upgraded Trim Actuator installed I hope.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 01-19-2021, 01:32 PM
AeroDog AeroDog is offline
Location: New London, NC (near Charlotte), Longmont, CO
I did it with the stabilator and rudder on (see my blog) then bragged that I was going to fly the airplane after having installed the stabilator only one time. When the time came to move the project from NC to Colorado, it wouldn't fit in the 18-wheeler with the stab on! Had to remove it, necessitating a re-do of the cable tensioning (an odious task).
Jerre
jerre-hill.blogspot.com
Empennage, fuselage and wing kits complete
Canopy in progress, engine in the hangar.
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2021
Old 01-19-2021, 09:36 PM
RFSchaller RFSchaller is offline
I put my rudder and stab on and did not remove them again until it had to be painted about 50 hours after first flight.
