Old 01-12-2021, 03:07 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default First flight of the year! ... flat tire :-(
Shirley and I went out for our first flight this year. Sunday was not the best day for ceilings, however turbulence was low and we had a nice flight.
Upon our return (CYRP), our landing was fine and we long taxied to the taxiway, but something did not seem right. Needed a little more power than usual and some strange vibration. Stopped near the threshold of 04 so as not to impede any other traffic and stepped out to check on the tires. Yup, front tire is flat. Called the FBO to let them know of our predicament and that we were going to get some tools from our hangar and attempt to inflate the tire.
A hangar neighbor Jeff offered us a dolly in case the tire would not inflate or remain inflated long enough for the taxi back to the hangar. Jeff actually took the screwdriver from my hands and eagerly started working on the wheelpant. Thanks Jeff Whaley.
After removing the nose wheel pants, we tried tire inflation and the indications were that there must be a large leak. Lifted the nosewheel and strapped it to the dolly. Used the towbar with a McGyver'd tow attachment to the trailer hitch. A slow walking pace back to the hangar ensued while being very attentive to cracks and ice on the ground (the castoring rollers on the dolly are small and hard offering no suspension).
I have the nosewheel at home now and will take a look in the next few days. The rim is fine, though the tire will need replacing due to rubbing marks. I am sure the inner tube is toast as well. Made for an interesting day... if you take a positive spin on it. Jeff and Matt were there to check up on us and offer assistance. On tow back, we had ourselves a convoy.
Edit: Jeff sent me a video of the towing back to the hangar https://www.youtube.com/watch?v=QM3N...ature=emb_logo
Click image for larger version
ID:	6900  Click image for larger version
ID:	6901  Click image for larger version
ID:	6902  Click image for larger version
ID:	6903  Click image for larger version
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 01-12-2021, 04:13 PM
Vlad Vlad is online now
Congrats on first flight of the year Alfio! Itís a good thing the flat happened at home airport
Old 01-12-2021, 05:08 PM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
Had my first flight of the new year today. It just so happened that I thought it was time to check tire pressure again. Glad that I did. Cold temperatures always lower tire pressures and a little preventive maintenance is always a good thing. This time of year I recommend checking pressures at least every other month.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 01-13-2021, 07:22 PM
Lycosaurus's Avatar
Default Tire pressure check
Yes, checking tire pressure more often is the key. Glad it happened on home turf.
Alfio
> 1,000 hrs tach.
Old 01-14-2021, 01:26 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default cause?
Hi Alfio - were you able to find the source of the flat? Inquiring minds want to know!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-14-2021, 06:58 AM
Lycosaurus's Avatar
Have the wheel at home now and plan to crack it open in the next few days.
I brought back home tools and supplies for working on the wheel, as our province is in a lockdown (of sorts) for the next 28 days.
Alfio
> 1,000 hrs tach.
Old 01-15-2021, 08:25 AM
Lycosaurus's Avatar
Default Towing
Jeff sent me a video of our baby being towed back to the hangar:
Have also updated the original post.
Alfio
> 1,000 hrs tach.
