Old 07-01-2007, 07:12 AM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Default Isolating Ground on Music Input Jack
Looking for some ideas....
I will installing a music jack which will be connected to my PS8000B audio panel.
If a music jack is installed PS Engineering highly recommends that you isolate the jack from the airframe ground by using by using an insulated mounting plate.
I would like to install the jack on the upper gear leg tower on my -8.
Are there any commercially available jacks or components that will address this?
Anyone solve this problem yet?
Thanks in advance for any suggestions or gotchas.
Mike Draper
RV-8
Finish
Hartzel prop just arrived
Old 07-01-2007, 07:26 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
You want part 161-7300 from Mouser. It's a panel mount, plastic bodied jack. Here's a link: http://www.mouser.com/search/Product...key161-7300-EX
I originally found it from Checkoway's site.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 07-01-2007, 08:15 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I originally forgot to isolate the jack, and got a nasty whine....so definitely you want to do this!
I couldn't find a plastic jack that I wanted when I wanted it, but found that the metal-bodied jack I had fit perfectly into one of Van's hard plastic grommets. With a touch of glue, I had a nicely isolated plastic jack that clicked right into the hole....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-01-2007, 09:01 AM
fstringham7a fstringham7a is offline
Default HELP TECH Challenged
Paul
Paul and others that have added music to thierr system. I am installing the garmin GMA 340. Now the ????? I will be using an MP3 or Ipod for music imput so how does it get wired to the panel/GMA 340.
Thanks in Advance
Frank @ SGU RV7A Panel/Electrical "NDY"
Old 07-01-2007, 09:10 AM
Thanks everyone.
Great information and all on a Sunday morning!
Paul, good idea to use one of Van's grommets with a touch of expoy.
I may event get this task done before the Red Sox game today!
-Mike
Old 07-01-2007, 09:23 AM
Ironflight's Avatar
Frank,
I don't have a 340 install manual or pin-out diagram, but look for the "Aux Music In" feed (or something named like that...), and wire up a mini-jack to that. Get yourself a cord to go from the iPod to the mini-jack, and voil?! Music into your audio panel.
Assuming, of course, that the 340 supports an Aux audio input....
Paul F. Dye
Old 07-01-2007, 09:24 AM
aadamson's Avatar
aadamson aadamson is offline
Thanks in Advance
Via the entertainment in connections on the audio panel.
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
