Old 06-29-2007, 04:46 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Default Gascolator Doubler Installation
I ordered and received my doubler to do it before I finish the forward structure. Where are the plans to install it? Do they come with the FWF kit and if they do, can some scan their's and email them to me? Thanks.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 06-30-2007, 01:12 AM
jlfernan's Avatar
If I could get maybe a photo of the blowup showing placement and rivet callout?
Jorge Fernandez
Spruce Creek, FL
Old 06-30-2007, 06:14 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
E-Mail scan sent.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 06-30-2007, 10:53 PM
Norman CYYJ Norman CYYJ is offline
It goes on the right side of the firewall and will only fit in one and only one place. Place it there and drill the many rivet holes required and rivet it on. Use flush rivets with the heads on the firewall side, if you are not mounting anything else there machine the bracket and put the rivet heads on the inside. If you put the heads on the fire wall side either dimple the firewall and machine the bracket or lightly machine the firewall and use NAS rivets to hold the bracket on with.
NAS rivets=oops rivets. I use them for all my nut plates etc saves a lot of dimpling etc.
Old 07-01-2007, 10:50 AM
macrafic's Avatar
macrafic macrafic is offline
Default Me Too!
Originally Posted by robertahegy
E-Mail scan sent.
Roberta
Roberta, can you send a scan to me also? I'm building my firewall and had just ordered the bracket a couple of days ago. Thanks.
Old 07-01-2007, 10:56 AM
If I had your e-mail I could.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Glen L Torpedo
