Old 12-27-2020, 06:11 AM
RV6-KPTW RV6-KPTW is offline
I used a chunk of interior leather (pleather?) cut to fit, with edging and two computer fan covers holding down the center. No movement and no glare.
The edge trim and fan covers are available on Amazon: trim-lock edge trim. 3/16 works better than 1/8. If you live in the area, I have plenty of both and am not sure what to do with them.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/18/2020 * 2
Old 12-27-2020, 07:49 AM
lr172 lr172 is offline
Originally Posted by bbsdad View Post
Get a set of ear seal covers to fit over the gps antena. The one’s for a David Clark work grate.
RD
I sanded both of my GPS antennae with 400 grit sand paper. It makes for a nice flat finish that reflects no light.
Larry
Old 12-29-2020, 05:07 AM
RViator60 RViator60 is offline
Dennis, that's a great suggestion. I ordered a length of 3/32" Trim-Lok, some 0.05" PU faux leather, and a couple of fan covers from Amazon. I imagine I'll need to glue the edge of the faux leather to the Glareshield to slide it into the Trim-Lok. I'm hoping the thicker fabric will lay down without any face along canopy edge. If I lived closer, I would definitely have dropped by to see your installation. Thanks.
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wings and fuel tanks completed,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite delivered.
- Currently working on fuselage
https://eaabuilderslog.org/?s=MartysRV14A
Old 12-30-2020, 05:48 AM
Marty, just allow 1/2 or so extra of the pleather to hang over the glare shield trailing edge, fold it under, and install the trim over to lock it in place. No need for glue anywhere. I can take a photo later if needed.
I used 60mm computer fan grills from Amazon. Least ugly I could find.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-30-2020, 06:24 AM
cajunwings cajunwings is offline
Default Fan Grills
I just made my own out of .030” aluminum to fit the computer fan mount screw pattern. Painted flat black and they look like they belong there.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Click image for larger version
Old 12-30-2020, 06:53 AM
Kitbuilt Kitbuilt is offline
Default Fan Grills
I purchased a couple of these from Stein
https://www.steinair.com/product/def...n-cover-plate/
Joe Granito
Albany, NY
RV-7A
Emp completed
Wings closed
Fuse in the works
Finish kit Arrived
2021 donation sent
