Old 06-28-2007, 01:39 PM
Sparky's Avatar
Sparky Sparky is offline
Default New AHRS Mount Kit From Van's
I see that Van's now sells a new AHRS mount kit for the RV7 & RV9. Here's the link: http://www.vansaircraft.com/cgi-bin/...uct=AHRS-mount
The new kit installs the AHRS (I assume the magnetometer) for Garmin G900X or Grand Rapids Technologies (GRT) near the bottom rear fuselage skin just forward of the F707 (for the RV7) bulkhead and aft of the baggage (F706) bulkhead. I am installing a TruTrak pitch servo and it looks like the proximity of the ferrous materials in the servo assembly may not be compatible with this AHRS mount for my GRT magnetometer. Any thoughts?
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 06-28-2007, 03:32 PM
w1curtis's Avatar
w1curtis w1curtis is offline
The GRT AHRS and magnetometer are separate. Mount the AHRS on this mount and then mount the magnetometer elsewhere, like in the wing or further back in the tail.
GRT AHRS
Dual AHRS
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 06-28-2007, 03:40 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default More info
Correct, they are two different boxes. I chose to mount the AHRS forward of the panel under the forwardmost top skin. Just run a piece of angle on the lower flanges and between the ribs that run fore-aft back from the firewall. Mount the AHRS front on the firewall top horizontal angle and the rear will be perfecly level on your angle that's under the ribs. This keeps the wiring forward of the spar.
Van's, in my opinion, makes running wires a problem with inadequately sized holes and when you call about enlarging them they won't give solid advice because they haven't tested it.
As for the magnetometer, I mounted that on the flat deck just forward of the HS spar and aligned it 90 deg. (square) to that spar. That takes care of the critical alignment that GRT wants in all three directions. It is said to be sufficiently weather proof to be ok in this location under the intersection fairing.
picture.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Last edited by hevansrv7a : 06-28-2007 at 04:05 PM. Reason: insert picture of AHRS, magnetometer mounted
Old 02-24-2011, 01:25 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Revisiting an old post...
Is the Garmin 900X AHRS and Magnometer also split in 2 units?
I want to mount my Skyview AHARS and this is a convenient space, but the Pitch Servo and The RV10 rear battery and contactor in the vicinity has me worried about the magnometer in the Skyview ADAHRS.
Anyone confirm about Garmin 900X split, or skyview in this area.
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 02-24-2011, 05:12 AM
pierre smith's Avatar
Default Say....
Originally Posted by hevansrv7a;135787
...As for the magnetometer, I mounted that on the flat deck just forward of the HS spar and aligned it 90 deg. (square) to that spar. That takes care of the critical alignment that GRT wants in all three directions. It is said to be sufficiently weather proof to be ok in this location under the intersection fairing.
[url="http://home.cogeco.ca/%7En17hh/IMG_3204.jpg"
picture.[/url]
[/font]
...Is the magnetometer not supposed to be tilted forward the same number of degrees that the panel is angled at? IIRC, when we installed my buddy's magnetometer in his -4, we made an angled bracket after we measured his dash inclination, according to Dynon's instructions.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 02-24-2011, 06:51 AM
flion's Avatar
flion flion is offline
Rudi, the Garmin AHRS and magnetometer are separate. This location is fine for the G900X AHRS. Garmin currently does not give specifics of an RV-10 magnetometer installation despite several flying (and therefore Garmin certified) installations. Going by their guidelines, the unit would have to be flying formation with the airframe, because they want 3 feet from ferrous materials or power-carrying wires and six feet from any motors. However, I am told by at least one other -10 builder whose aircraft is equipped similarly to mine that their installation of the magnetometer at the rear fuselage deck between the HS spars worked fine and was Garmin certified despite the proximity of trim motors, tail strobe, and elevator horns.
Sorry, I have no information on the Skyview. Pierre, the magnetometer in my BMA system was designed to be aligned as close as possible to level in cruise. For RVs, this meant installing level with the fuselage longerons and then doing a software level setting in flight. The Garmin unit is also intended to be leveled relative to the aircraft, not the panel.
EAA Technical Counselor #5357
Old 02-24-2011, 10:04 AM
jjconstant's Avatar
jjconstant jjconstant is offline
For my GRT system, my foggy memory is that the AHRS needs to be aligned fore and aft with the direction of flight and the magnetometer be as close to the same alignement as the AHRS. Differences in the alignement between the two results in a magnetic heading that is an "amplified" amount off.
Although I may be misremembering things from LONG ago
Jeremy Constant
RV7A100hrs
Old 03-08-2011, 04:24 AM
Update, for future reference...Putting the Dynon Magnemeter here is not a good idea if you are going to fit a AP Servo. Those magnets is the Servo's cause Havoc. You need to be at least 2 ft away for a normal magnetic compass not to sway in the tailcone. I tested and need to make another plan
