Closed Thread
  #31
Old 09-17-2007, 12:04 PM
N787R N787R is offline
Default Do not have order form
Mike I did not get it. Please try again
behnam@ahmadians.com
  #32
Old 09-17-2007, 12:20 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default I got mine----------
But I am a bit shocked at the prices.
For my 10, from Vans a full set of belts/shoulder harnesses is apx 320.
From the order form, the same from Hooker is 520.
So, thus the question????
Are the Hookers worth the extra $200??? for a non aerobatic airplane???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
  #33
Old 09-17-2007, 02:38 PM
shiney shiney is offline
I can't answer that Mike, all I know is that the Hookers I've seen on the RV7's around here are great quality. I'm not promoting Hooker above any other, I have organised the group buy only becuase from day one my harness of choice has been Hooker, I had one in my Pitts and it was superb, so for me its very much a personal choice based on past experience.
Regards
Martin
  #34
Old 09-17-2007, 03:19 PM
Mike S's Avatar
Senior Curmudgeon
Martin, thanks for the response----------seems to me that in a Pitts or something else that spends a lot of time other than straight/level, this might be an issue.
Anyone else have a comment ???
Mike Starkey
VAF 909
Rv-10, N210LM.
  #35
Old 09-17-2007, 03:33 PM
BillC BillC is offline
Mike,
There were a couple of group buys for CROW harnesses. I went with them about a year ago and everyone who sees them comments on how much better that the Van's harnesses they are. Not up to the same standards as Hooker but a step up from Van's and slightly less expensive than Van's. Check out the Crow group buy threads.
Good Luck
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
  #36
Old 09-17-2007, 04:46 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Order Placed
Martin-
If you are keeping track, my order was placed today.
Sport 5 point harness, rotary buckle, dark gray belt, dark gray pads, black trim with navy blue pull tabs.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
  #37
Old 09-17-2007, 05:41 PM
Thanks Peter,
Not having run one of these group buys before I'm not sure of the procedure but I figure that when you have sent your order, send me an email so that I can check it against the original list, that way I'm not likely to miss anyone out.
Martin
  #38
Old 09-17-2007, 05:44 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by BillC View Post
Mike,
Good Luck
Bill, thanks for the info.
Mike Starkey
VAF 909
Rv-10, N210LM.
  #39
Old 09-17-2007, 05:47 PM
sjjonesnz sjjonesnz is offline
Default Confusion reigns
Does anyone have a picture or somesuch showing which is the trim on these harnesses and how it relates to the padding/webbing?
  #40
Old 09-17-2007, 06:10 PM
AltonD's Avatar
AltonD AltonD is offline
try www.hookerharness.com
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Closed Thread
