Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 01-22-2005, 09:22 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Default Climb rates with a Catto
Howdy all,
I've got a 200HP IO-360 and a 3 blade Catto prop. As I've said before, it is smooottthhhh ;-) The best sustained climb rate I've seen is about 2200 fpm, although I did get 2500 for a minute or so once before I hit the floor of some terminal space and had to level out. This 2200 fpm is with 1064 lb empty weight, 3/4 fuel, and a 300lb plus pilot (don't ask ;-) Outside temperature was in the 30 deg F range.
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
