Old 06-27-2007, 06:53 AM
prkaye prkaye is offline
Default painting metallic colour
Still years away from painting, but always thinking/planning ahead. My paint scheme ( www.c-func.com/paint ) has most of the airplane in a shiney metallic gold colour. I've been told that painting such metallic finishes is very difficult to make them look good. This is one reason why I may save my pennies and have it done professionally. But I will still consider doing it myself... do any of you guys have any knowledge/experience with painting metallic colours such as this? Is it really difficult to get a smooth good finish? Keep in mind I've never done any aircraft or automotive painting at all.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 06-27-2007, 08:36 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Get Guidance
It is not that difficult but getting some professional guidance, having a place to paint and the proper equipment make all of the difference.
I was fortunate to have all of the above. I used four colors, two of which were metallics. I used a base coat and clear coat system. It is much harder with single stage because you only get one shot at getting it correct.
Don't worry about the thought that the metallics causing potential interference issues with radios. According to my paint guy, he said most metallics paints use non metallic particles to get the affect.
You will need to check on the specific paint you are using. Even still I believe the chance of issues would be minimal.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 06-28-2007, 08:40 PM
Captain Avgas Captain Avgas is offline
Phil, you're pondering over whether to paint your plane yourself or not. I reckon this is a very easy question to answer. If you reckon you have enough skills to paint your car...paint your plane. If not.....get a professional.
If you want to save money see if can make arrangement to do as much of the labour intensive prep work as you can.
I'm amazed at the number of builders who would never dream of repainting their car.....but are quite happy to botch up their plane.
Personally I've never seen a top notch paint job done on a plane by a first up painter. I'm SURE they must be out there....but I'VE never seen one.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 06-28-2007, 09:10 PM
w1curtis's Avatar
w1curtis w1curtis is offline
Hmm, I find this logic a bit ah, illogical. Most of the folks on this forum wouldn't BUILD a car either. What is the point of this comparison?
All the skills that one learns when building an airplane, why should painting be any less daunting? While it is likely that very few first time builders will build perfect planes, does this mean that they should not attempt it? That is your implication.
You should get out more. I've see builders do at least a good a job as professional shops. What are you building and will the lack of perfection deter you from building and just purchase a professional built aircraft?
Many builders have varying degrees of skills and patients and what one builder loves or wants to do, another may choose to outsource and have someone else do. Some will build up and engine while other would prefer to buy one ready to bolt on. Other will build their panels from the ground up while, another would outsource to one of the many panel builders. Some will choose to sticth their interior, while others will drop everything at the upholstry shop and pick up the completed parts. Why do you think aircraft painting should be the exclusive domain of professional?
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 06-28-2007, 10:11 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Not sure about that, as I'm actually impressing myself with my first time paint job. Lot's of research and time, but it's looking good!
BTW-- no decals or vinyl masks. All laid out & taped by hand.
[img=http://img165.imageshack.us/img165/9392/dsc04899pk0.th.jpg]
Old 06-28-2007, 10:57 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Nice work! I am going to paint my RV-7A myself also...I've done very little research because I'm still building, but I've heard that some types & products are much more forgiving than others (meaning they would be great for someone who is just learning to paint). Can you tell me what you're using?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 06-29-2007, 12:18 AM
Brian Vickers Brian Vickers is offline
Default Metalics
Phil,
I like to spray paint and have refinished three cars and an aluminum boat (Lund) using metalics. I have very good equipment but skill is a bigger part of shooting metallics. Single stage is not difficult to lay flat but it is hard to keep from looking zebra striped. The back and forth overlapping patterns are difficult without considerable practice. You can easily get areas where the paint pools inconsistently at then in the right light you can see your back and forth pattern (zebra). Base coat / clear coat is easier for sure. It is impossible to touch up if you ding it.
Before I shoot metallics, I go to an auto body shop and acquire their left over metallic paint they don't want. Usually small quantities but better than paying for it. This is a great way to work on your technique and dial in your equipment. Thin it down slightly to replicate the catalyzed/reduced paint consistency. Use a hard, non porous surface for the practice material. Cardboard and paper is too absorbent. White Melamine is ideal.
I am going to paint my own plane in a few months myself. No metallics for me. I don't want a zebra in the hanger.
Brian Vickers, RV4 finishing
Old 06-29-2007, 11:46 AM
w1curtis's Avatar
That looks pretty impressive to me too. What paint system are you using and what is the paint code for that yellow and gray?
William Curtis
Old 06-29-2007, 01:47 PM
Allen Barrett Allen Barrett is offline
Like Brian, I have had my share of painting autos. A trick used by most single stage painters is to start the second coat a pass or two foward of the first coat. It helps in overlappig your coats and eliminates the stripes.
Allen
Old 06-29-2007, 05:46 PM
L.Adamson's Avatar
For you, and the other person's reply, that wanted to know.
It's Sherwin Williams Genesis 3.5. A high end fleet vehicle paint, that's similar to S/W Jet Glow ( as I've been told). It's single stage, and the yellow color is a match to a Nissan X-Terra, by placing the color card up to the actual vehicle, because the listed color was a shade too light.
The gray, which I don't remember the numbers is just a light gray.
FWIW, this paint was still around $1400.00 for a gallon of yellow, two gallons of gray, and a quart of black & white, plus the hardener; and gallon of primer/hardener. And then throw in a few more hundred dollars for lot's of 3M green tape, 3M blue flexible striping tape ( like vinyl electrical tape), and some pin strip tape, plus painting paper & plastic covering.
Colors such as red & yellow, are much more expensive than the gray.
It looks like I'll have about a gallon of gray left over, and I initially have wasted a bit of paint, because I didn't know how much to mix in the first place. There is only a few hours shelf life, after the hardener is mixed, at best.
The gray easily coats in two coats, while the yellow can range from four to six. It's not a thick build up of paint, but just less pigment; and doesn't hide other colors well. Use the white primer, and spray yellow first while bleeding it down six inches or so into the gray area. The first coat of gray, actually totally covered the yellow.
Once this brand of paint is dry, it's flexible and stands up to a long list of solvents, fuels, etc. One of it's recommended uses for fleet vehicles, is for graffiti, as it's easily wiped off, without paint damage.
I too, started with some streaking on the vertical & horizontal stab, until I got the hang of it. Watching an old EAA aircraft painting video really helped, including laying out the stars & stripes.
With the initial colors of yellow and gray in mind (as I didn't want to shoot metallic silver), and a want of invasion stripes, even if it's a nose wheel version, but I'm still a die hard P-51 fan
......... some thought the look might be a bit dull. I had a downloaded screenshot of a Harmon Rocket, or F1, that's similar to this color scheme. By transposing the yellow to the Rocket/F1's blue color, I knew that the yellow would look interesting! And now those, who thought it might like dull, keep bringing over others to see it!
All surfaces, except underneath the plane are done with an HVLP, since I'm just using gravity feed.
And BTW, this stuff is quite toxic, and a fresh air setup works the best.
L.Adamson RV6A
