Old 12-08-2020, 08:40 AM
Dennis Harm Dennis Harm is offline
Default Rv14A throttle
Just wondering if anyone has had a stiff throttle movement the first 1/2 inch or so. I have the avstar fuel servo and Vans stock throttle cable. The stiffness is not in the cable as it was smooth before hooking up the throttle arm, thanks Dennis
Old 12-08-2020, 09:03 AM
Ron B. Ron B. is offline
Never noticed anything on mine. Do you feel it if you just move the arm by hand?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-09-2020, 07:17 AM
Default 14 throttle
Hi Ron, removed the throttle cable and throttle arm moves free. Do you have the offset throttle arm or did you change it out to straight arm? Not sure if the offset arm would cause friction somehow. I know Tim Olsen changed his out to a straight arm. Thanks Dennis
Old 12-09-2020, 09:02 AM
I'm quite sure I used the arm Tim used but I have a poor memory. I have the cowl off because I'm doing the nose gear SB so I will have a look.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-09-2020, 10:47 AM
lr172 lr172 is offline
[quote=Dennis Harm;1483870]Hi Ron, removed the throttle cable and throttle arm moves free. /QUOTE]
Look for binding in the heim at idle position.
Old 12-11-2020, 08:33 AM
Default Throttle stiffness
Hi guys, have ordered the straight throttle arm from avstar and will see if that helps. lr172 what is heim . Iím assuming itís the mixture arm connected to the throttle arm. Thanks for the replyís, Dennis
Old 12-11-2020, 09:01 AM
Heim is the ball joint, make sure it can swivel around and doesn't bind.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 01-02-2021, 07:03 AM
Default Throttle arm
Just a update on the avstar throttle arm. Installed the straight arm I received from Avstar and it made a big difference. Movement is now smooth Thur out the travel on the throttle. Thanks Tim O for the part number and advice
Old 01-02-2021, 08:31 AM
Tmartin66 Tmartin66 is offline
I'm having the same issue. Dennis, do you mind posting the part number you spoke of?
T. Martin
RV-14A
N114TM Flying - Nov. 2020
Dues paid 2021
Old 01-02-2021, 08:09 PM
Part # is AV2522004. You can order on Avstars web site.youíll also need a different bolt as you donít need the spacer any more. I tkink itís a An3-10 that fits.
