Old 06-26-2007, 03:55 PM
s_tones s_tones is offline
Default Jump starting RV series of aircraft
Occaisionally my Piper gets a little finicky and doesn't want to start.
I've yet to actually get stuck somewhere though I nearly did one evening in Monterey. Anyway, the thing is, it is jumpable. That is to say you could manage to input the requisite 12V and get her going if you ran the battery down.
Sooo...the question is, how do you jump an RV with the battery sitting up there under the cowl? Do any of you guys put in power recepticles?
Steve
Old 06-26-2007, 04:10 PM
prporter prporter is offline
Default Una respuesta por la pregunta muy estupido
Yes.
AX-O's Avatar
AX-O AX-O is offline
Some people run wires and a plug to a point on the rear of the fuselage. Most that I have seen are behind the left wing.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
There are no stupid questions.
Mike
Old 06-26-2007, 04:14 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I ran leads off the battery with a plug that connects to my trickle charger. I suppose I could get a slow charge off another charger in a pinch. Couldn't jump start it, though. So far my venerable PC680 hasn't failed me in over 3.5 years.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 06-26-2007, 04:17 PM
mgomez's Avatar
mgomez mgomez is offline
Default Except in Spanish...
Mike
...where there are male nouns and female nouns. Female nouns get female adjectives.
Thus "Pregunta estupida", not "Pregunta estupido." But we native Spanish speaker appreciate the effort!
But I'm glad you asked, because I've been wondering what to do about an external power receptacle. So some of you run big starter wires all the way back to behind the wing?
Otra pregunta estupida: How do you route those big wires?
Martin
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 06-26-2007, 04:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Piper External Power Jack
I mounted a Piper-style external power jack under the fuselage (rear mounted battery in the -8) so that I could jump it if required, and more importantly so that I can power the ship while working on avionics (all glass - lots of software loading and configuring). Bob Knuckolls has an article on his site about how to modify it to work well - easy and cheap (like $18 for the receptacle!).
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-26-2007, 04:36 PM
jclark jclark is offline
Default Plug accessible via oil door ..
Steve
I have a power plug (actually two) attached to the engine mount and accessible via the oil door.
The first one was for trickle charge of the battery during old weather etc. It is a female part of the "cigarette lighter" jack/plug. The male end is attached to the trickle charger and I just plug it in as required.
But ... back in February, while in Punta Gorda, FL with a "weak" battery, an **ICE-STORM** (or was it freezing rain or something) came through overnight with the plane on the ramp. It did not want to start (I knew I had a weak battery ... was going to replace it as soon as I got back).
Had a bit of trouble getting the jumper cables attached for a start. :-)
So I vowed to not get caught like that again. Went to a "Marine" store I think and got one of their "power plugs". Flip top cap (spring loaded) and two large prongs. Not much bigger than the 12v receptacle mentioned above but with much bigger wire. Connected that to the battery and attached the other end to a small set of jumper cables that I keep in the plane. I can now get a jump start just about anywhere.
Hope I neve *have to* use it. :-)
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 06-26-2007, 04:53 PM
Thanks you guys. That was really buggin me.
Y, lo siento por mi muy estupido mistako!
Steve
Old 06-26-2007, 05:57 PM
N941WR's Avatar
N941WR N941WR is offline
Default This will not help you jump it but...
I wired one of my two "cigarette lighter" jack/plugs on the "Always Hot Bus" so I can leave a trickle charger on it while in the hangar.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
