06-26-2007, 02:09 PM
Drill up plexi with unibit?
I know it's OK to drill #40 with a normal drill then increase the hole to final size with a plexi bit, but is it also OK to drill #40 and then increase the size with a unibit? I'm ready to drill the hole for my canopy latch handle and would like to use the #40 to make sure that my hole is centered. Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
06-26-2007, 02:43 PM
We have just finished doing just what you plan and we had no trouble. However, when we were enlarging the #40 holes to 5/32", we found that the steps on our particular step drill bit were too close together to allow us to drill all the way through the plexi so I ordered a plexi drill from Air Craft Spruce and it did just fine.
Good luck! I know I am tired of fooling with this canopy business, aren't you? We're installing the rear canopy block now and trying to figure out how to get the angle of the hole for the spike just right!
Cleve Thompson
Waycross, GA
Flying a RV9A with O-320 from KAYS
since Dec 2007 & having a blast
06-26-2007, 03:14 PM
Like this
Hi Cleve,
I'm assuming that you're speaking of the two blocks that house the pointed hold down pins? Get in the airplane and let your helper close the canopy until the point touches the rear of the block. Hold a ruler at the same angle as the pointed rod and transpose that extended line onto the side of the block with a colored marker. Open the canopy and stand on one side of the airplane while the driller aims the drill with you looking at the drill's angle compared to the line on the block. Tell him to raise or lower the drill to match the line and drill away. Later the entrance to the hole can be enlarged into a funnel shape to help guide the pin in as the canopy closes.
Regards,
Pierre
ps You may have to start drilling perpendicular to the block until the drill starts going in and then angle it up while it spins.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
06-26-2007, 08:21 PM
Thanks Cleve-
Yes, this canopy stuff is getting old! Still, I just made my first cuts in trimming off the fwd. and aft flanges. Did one test cut and then went right up to the edge of the flanges and cut them very cleanly and left a finished edge smoother than what came from Van's. I'm very relieved that it went well and that the plexi didn't break just by looking at it wrong!
The steps on my unibit are too shallow too, so maybe I'll have to get a big plexi bit for the canopy handle hole if my friend doesn't have one.
Good luck on those rear blocks. Thanks for asking the question before I got there!
Steve M.
Ellensburg WA
06-26-2007, 08:28 PM
Don't forget that you can drill halfway through the hole with the unibit, then come at it from the other side and finish it off. Worked for me!
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
06-26-2007, 08:38 PM
The Canopy Stuff Gets Old?
I didn't think so. This is one of the most eye catching parts of the whole airplane and impatience at this point is a bad thing. I compromised nothing on this part of my plane and took several extra precautions to assure a good closure seal. I've never regretted it but we each have our own priorities. Good luck. I would never have tempted fate with anything but plexiglass drills on the canopy and lenses but obviously it works.
Bob Axsom
06-26-2007, 08:41 PM
mcb
It's a good suggestion. Actually finishing off the hole with the unibit from the rear is safer. Damage to the plexi always occurs on the break-out side of the plexi....and increases in risk with larger holes.
Go most of the way through from the front and then come in from the rear to just finish off. If you have any microscopic damage on the rear it will clean it up.
You’re only as good as your last landing
Bob Barrow
RV7A
06-26-2007, 11:21 PM
Bob Axsom
Not sure whether you are trying to encourage me or discourage me Bob. Sometimes it's hard to tell on the internet. I don't think I'm being impatient and am not trying to compromise anything. Like you, my priority is building my canopy to the best of my abilities. Van's instructions say to use a unibit for this process, so my first thought is to follow directions and use a unibit. If you have a source for 5/8" plexi bits I'm interested in hearing where. Spruce doesn't carry anything that big that I can find. That said, I'm glad you really enjoyed the stressful/high dollar $$$ part of the building process. I've enjoyed learning a new skill but will be quite pleased when it's all done and I don't have to do it anymore.
Matt and Bob B.--Thanks for the suggestion at using the unibit I've got and coming at it from both sides. My initial thought was that maybe I wouldn't be able to center the bit perfectly on the backside given that most of the material will have been taken out on the first side. I'll give it a try though on some of the scrap.
Thanks again, Matt, especially for your canopy notes. They've been really helpful.
Steve M.
Ellensburg WA
06-27-2007, 12:46 AM
You got me!
WOW 5/8"! I don't have a plexiglass drill larger than 3/8" so I decided I better back check. I got my photo log (album) down and found the series where I was working on the canopy. I saw no evidence of what tool I used for the large latch hole but all of my photos have the date they were taken written on the back. It was in September of 1998 that I first set the plexiglass on the round tubular canopy frame and rollover structure. On 10-17-98 I found the following entry: "... I've drilled and enlarged the hole for the latch." Still no clue as to the tool used so I got out the instruction manual. On page 9-9 in my RV-6A manual it says "A large hole must be cut for the latch tube - - use a Unibit and drill this hole as accurately as possible. If the canopy must be adjusted after the hole is drilled, it may be carefully "ovaled". The trim strip along the top tube will cover it up later." Based on the evidence I can only guess that I drilled a pilot hole with a 1/8" plexiglass drill, then enlarged it to 3/16" or 1/4" with another plexiglass drill so the smallest diameter of the unibit would enter it and then enlarged it to the final size. I bought my plexiglass drills from Avery Tool and the 3/8" drill for the wing tip lens mounting holes was the largest. I do not know if they have larger diameters. I was wrong in my apprehensive reaction to the use of the Unibit for plexiglass applications - thanks for straightening me out - I'll be more careful in the future.
Bob Axsom
06-27-2007, 01:31 AM
Matt, go as far through from one side with the Unibit as you can and then come in from the other side to finish off the last bit ....then you won't get misalignment. But your intention of practicing on scrap is excellent. I NEVER practice anything on my plane.
I actually bored out all my canopy holes to 1/4" and used silicone bushings to allow for differential thermal expansion. I used a plastic drill up to 1/8' and then a unibit above that. In reality a good unibit with small steps is better (read safer) than a plastic drill but in practical terms you need a 1/8" hole to get started with the unibit.
Keep things warm. Be very careful with countersinking as well ...big danger there. The less flutes on the countersink the better. One flute is best, two flutes just OK, 3 flutes dangerous.
I would suggest that most of the cracking seen in canopies (and there's a LOT of cracked canopies) is cause by one of 3 things: a) initial microscopic damage to holes by poor technique in drilling and countersinking. b) misalignment between holes in the canopy and holes in the frame. c) poorly fitting canopy on frame resulting in localised plexi stresses being built in.
I'm with Bob Axom when he says the canopy needs to be done carefully and with patience. Many builders I know are using the 'take-no-prisoners' approach to building....they just keep throwing things together. But that approach will not work for the canopy. Every really nice fitting, well finished, smooth sliding canopy I've ever seen had a LOT of time spent on it to get it that way. Come to think of it....it's the same with the rest of the plane.
Bob Barrow
RV7A
