Old 11-25-2020, 10:00 AM
RVFan671 RVFan671 is offline
Default Which stainless rivets for firewall and where did you buy them?
From research on the forums it seems like stainless rivets are the way to go on the firewall for protection. I'm wondering what part number you are using and where you got them.
I found (and ordered) a very small amount of MS20427F3 and F4 (with -X suffix for length) from Spencer's Aircraft but they had extremely limited sizing and I don't want to be cutting rivets. I couldn't find any on ACS.
1) Are my part numbers correct for the SS rivets suggested for the firewall?
2) Where are you buying yours?
Bought an O-360 RV4 to fly while building a -10.
Emp completed September 2020
Fuse started October 2020
Old 11-25-2020, 11:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
The thing about researching something like this on the forums is that you get a lot of folks that have never finished an airplane who have lots of time to postulate on forums....
More than 10,000 RV’s are flying, and I would wager that the majority of them are using the aluminum rivets that Van’s specified on the plans. And I know of no bad incidents that have occurred because of it - never heard of a single one (and I have a pretty broad information gathering system in experimental aviation).
Build it how you’re comfortable with, of course - but be careful about which rabbit holes you go down - too many of them connect to a labyrinth from which you’ll never escape....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-25-2020, 11:26 AM
fixnflyguy fixnflyguy is offline
Default Be careful in your SS choice..
As Paul reflects, it my lead to other things you aren't prepared for. I work in the heavy jet industry and shot many a SS rivet, actually the Monel being the best choice, however, it can lead to disaster if you have a short edge margin, or need to drill one back out. I have yet to read a factual report about a burn through issue worth worrying about to that level...just stay per plans and move in is what I would suggest.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-25-2020, 11:40 AM
pilotkms's Avatar
pilotkms pilotkms is offline
I personally know 2 engineers that have elected to change certain parts on their RV builds. After all, they ARE engineers. Both started their builds years ahead of me. NEITHER have finished their RVs. I’ve been flying for over 3 years. They like to look at their project and talk about how they’ve improved their build. Maybe some day they fly. Maybe not. Listen to Paul.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
700+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 11-25-2020, 11:53 AM
rzbill's Avatar
rzbill rzbill is offline
I have seen the results of a fuel fed engine compartment fire on an RV (not mine).
Do not be concerned with aluminum firewall rivets.
The heat of the fire will follow the normal airflow pattern to exit at the bottom of the cowl.
DO be concerned with the aluminum floorboards under the rudder pedals.
On the observed craft, there was a melted hole in that area.
It has been suggested to cover some of the bottom skin with stainless.
While I have not done it (the suggestion was post construction), I think it is a good thing to consider.
Bill Pendergrass
ME/AE '82
Old 11-25-2020, 12:14 PM
1001001's Avatar
1001001 1001001 is offline
For what it's worth, I considered using Monel rivets on the firewall, but decided to build with the standard aluminum rivets. My reasoning was that since I plan to fire insulate the firewall as discussed in other threads here anyway, that the aluminum rivets would be adequately protected in the event of a fire by the insulation and titanium sheet over the engine side of the firewall.
Old 11-25-2020, 01:41 PM
DanH's Avatar
DanH DanH is offline
By test, they are.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-25-2020, 07:57 PM
Ok, I've been convinced to move forward with my plan B, which was to use the aluminm rivets. I was planning on the forward side firewall protection and the under belly to keep 'normal'rv10 heat away from the tunnel (still need to figure out how to attach the stainless to the alum skin).
Old 11-25-2020, 08:39 PM
scsmith scsmith is offline
.... - but be careful about which rabbit holes you go down - too many of them connect to a labyrinth from which you’ll never escape....
Spoken by a hobby spelunker!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 650
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 11-25-2020, 09:15 PM
Ironflight's Avatar
Uh, point of order...calling a Caver a “spelunker” is like calling a marathon runner a “jogger”.....
Paul F. Dye
