Old 06-25-2007, 01:59 PM
szicree szicree is offline
Default Do I need primer? (Fuel, that is)
I just built a new carbed XP360 with lightspeed/mag with the standard primer lines but am wondering if it isn't just one more thing to leak. I'll be based in SoCal and am hoping to hear from those running similar engines. Do you need a primer or is a squirt from the carb adequate? Thanks.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 06-25-2007, 02:11 PM
Brian Vickers Brian Vickers is offline
Default Primer
Steve,
I don't know if you need it or not but I'm not installing a primer system. The two RV owners I know in my local area (Bremerton, WA) don't have primer systems on their airplanes either. I'm working on my panel right now and have plenty of room to add a switch if needed. I have been ordering parts from Van's lately and the fellow that has been helping me also suggested I omit it. He said to add it later if needed. It doesn't get that cold here in the winter.
Sincerely,
Brian Vickers, RV4 finishing
osxuser's Avatar
osxuser osxuser is offline
No, just two-three throttle pumps before starting.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-25-2007, 02:17 PM
McFly's Avatar
McFly McFly is offline
Default My two cents
I have a three line primmer on my engine.
My primmer seems to be good for making the engine backfire at startup but that?s about it. I never use it anymore and the engine starts fine.
My engine stated to lightly stumble intermittently on the Friday's flight (I doubt a passenger would notice). Turns out the T connection to the primmer line had become disconnected. I am going to rip it out as part of my first Condition inspection. It is dead weight on my plane for my neck of the woods. Good luck.
Hugh
Northern California
RV-7 Flying
Old 06-25-2007, 04:24 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Search
Check the archives, search\/ above on fuel primer. Lots of opinions. Did a quick search for you. My thought? You can always put it on later, but don't "carb prime" using the accelerator pump in the carb indiscriminately. Some carb prime only when turning the engine if possible.
The traditional thing is to put a primer on, but leaving it off saves a lot of weight, clutter and potential future maintenance issues.
http://www.vansairforce.com/communit...ghlight=primer
http://www.vansairforce.com/communit...ht=fuel+primer
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 06-27-2007, 12:17 PM
billnaz's Avatar
billnaz billnaz is offline
Default no primer
The Lyc. throttle accellerator pump is all ya need. Only pump the throttle while the engine is turning over though.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 06-27-2007, 03:43 PM
dwilson dwilson is offline
Default Throttle pump can cause fire!
I agree with the "pump only when the engine is turning over" idea. A local RV-4 owner had a small fire when he pumped before kicking the starter over.
My RV9A O-320 starts easily with one or at most two pumps from the throttle while cranking. Only been flying since Mar. 07 in the Pacific Northwest so can't comment on really cold situations.
Duane
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
Old 06-27-2007, 03:54 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default I had one initially...
Then when a line fatigued I removed the whole thing. No problems starting even when cold but I do preheat (oil sump heater) my engine.
Old 06-27-2007, 04:09 PM
Default I have a primer line going to 3 cylinders
I guess the choice is up to you. I have a primer solenoid in my console downstream of the aux. fuel pump. I put a full loop in ever 1/8" line of the system between the firewall and the engine and it works perfectly with no failures to date, ~350 hours. I bought one of the small butane torches from Aircraft Spruce to install the AN800-2 union cone on the ends of the primer lines. It was fairly simple to do and there isn't much to it.
Bob Axsom
Old 06-27-2007, 04:34 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
For SOCAL, forget it. For Alaska, maybe.
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
