Old 06-25-2007, 12:01 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Boost pump on for start and priming?
Kinda of a dumb question...
Does the boost pump need to be on in order to:
1. start the engine?
2. use the electric primer Van's provides in their catalog?
Trying to finalize the layout of my panel switches. Knowing the answer to both will help me.
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 06-25-2007, 12:08 PM
Mel's Avatar
Mel Mel is offline
For priming; probably!
For starting; no!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-25-2007, 12:14 PM
ddurakovich ddurakovich is offline
What Mel said!
For wiring purposes, I wired the primer solenoid into the electric fuel pump switch. Since it HAS to be on to feed fuel, and the solenoid requires very little current, it saves an extra breaker.
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
Old 06-25-2007, 02:55 PM
Default Only if you're interested in consistent performance
[O-360-A1A, Hartzell C/S Prop, LASAR Ignition] Set throttle, mixture and prop, turn the aux pump on, charge the system (look at fuel pressure gauge), press momentary primer solenoid switch (I count five seconds), turn on the starter, - ROAR - every time.
Bob Axsom
Old 06-25-2007, 03:03 PM
n468ac's Avatar
n468ac n468ac is offline
full cycle throttle once, set 1/4 throttle, mixture full, turn the boost pump on, wait to pump to quite, press momentary primer solenoid switch and count to 3 (if cold count to 5), wait (count to 10), turn key, starts every time warm or cold.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 06-25-2007, 04:23 PM
Mel's Avatar
Mel Mel is offline
Be aware that every engine starts differently. Mine uses 1 shot of prime the first start of the day. After that, don't touch anything but the starter button.
I can't imagine starting with 25% throttle.
Old 06-25-2007, 04:33 PM
Default My throttle is roughly 25% at start as well
My throttle is roughly 25% at start as well but that's just an initial point. I have my hand on the throttle and as soon as it starts I adjust for smooth moderate idle. As Mel says of course all systems are different and that includes fuel line routing. Mine has a several inch vertical rise before the engine driven pump and I never prime my engine when restarting after a short stop juch as for fuel. I think the boost pump is essential but the electric primer is an option for you to chose.
Bob Axsom
