Old 11-22-2020, 10:49 AM
BillL BillL is offline
Default GoPro flip down mount strength?
I am looking at an entry priced Hero and wonder if the standard flip down mounts can handle the load for external mounting, even under the fuse and subject to prop pulses?
BTW I did search and found no endorsement.
Any thoughts appreciated.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 12-01-2020, 06:34 AM
Bump, so nobody uses the Hero with flip down mounts externally? So what do you use?
Bill
RV-7
Lord Kelvin:
Old 12-01-2020, 07:11 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Bill,
A bunch of us are using PlaneAround wingtip and tiedown mounts. It's real solid machined aluminum stuff. Less likely to lose your Gopro with that.
The other day I had a Gopro 360 MAX (much larger than the Hero) on my Zlin50's wingtip, with just a standard stick-on mount. It did fine, but it's a slower airplane than the RV, I was doing around 120kts or so, indicated.
Lenny
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 700 hrs
OnSpeed development team
Old 12-01-2020, 12:23 PM
YellerDaisy's Avatar
YellerDaisy YellerDaisy is offline
I'm not exactly sure what "flip down mounts" are but I use the standard GoPro "stick-on" bases but with modification. I drill a hole in them and run a screw thru into an existing hole (wingtip screws or whatever). If you forget to tighten the finger-screw thing, the camera tips back into the airflow.
I fly very often (once a week??) with with three cameras, haven't lost one yet. You can kinda see the wingtip mounted cameras in my videos.
https://youtu.be/DExwUINF8gc
JD
RV-4 - 160HP O-320 - Sensenich GA
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
Old 12-01-2020, 12:32 PM
sjhurlbut sjhurlbut is offline
Show us a pic of what you mean by flip down mounts? You talking the legs that fold down like on a GoPro8? If so they're good to 190 kts so far.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - C-GVBX- building
Old 12-01-2020, 01:26 PM
Default Gold Star
Yes, Stu, the fold down legs as another name. 190KTAS is good.
To much $$$$ to fly away and become lost.
Thanks!!
Bill
RV-7
Lord Kelvin:
Old 12-01-2020, 01:33 PM
OK - folding legs - silly name, it won't stand on them, they are mounts.
Click image for larger version
Name:	Screen Shot 2020-12-01 at 2.28.13 PM.png
Bill
RV-7
Lord Kelvin:
