Anyone know off hand the size of the Vernatherm nut across the flats?
I changed to the straight back style of oil filter adaptor from the 45 up adaptor and my oil temps jumped 20F...Yes its been getting a little warmer out, but not 20F warmer.
So I thought I'd pull the vernatherm but I'm going to have to buy a wrench on the way to the hangar.
Frank I have a whole selection of wrenches and sockets. I'm out in the shops on Wake Robin on your way out to the airport. I'm half way down on the right and if my Miata or Red truck is there I'm there. Stop in next time you need something before you go out and buy.
Thanks Jim...I still have your number so I'll remember to give you a call.
I actually found a broken 1.25" rachet wrench that I can cut an maybe weld up to make the perfect tool ( a standard socket may need a lot of grinding to make it fit) so this might be the best thing to spend 20 minutes making.
