Old 10-31-2020, 06:58 AM
prkaye prkaye is offline
Default Canadian source for MS27215-2 Dessicant plugs
The “Dyhdrator plugs” that Aircraft spruce sells are poor quality and design (fragile, flimsy metal clip to retain fragile glass tube).
The MS27215-2 Dessicant plugs made by ProtekAir appear to be much more robust. (http://spenceraircraft.com/dessicant...ator-plug.html). I'm looking for a supplier of these in Canada. Do any of you know of one?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-31-2020, 08:12 AM
jrm7997 jrm7997 is offline
Default no idea if he carries them but id ....
No idea if he carries them but I'd call Dave at AeroParts Plus
1-250-395-8103
RV6A Flyer not Builder
CZBB
Shop/Tech Educator
Old 10-31-2020, 08:36 AM
terrye terrye is offline
Try Aerosport Power in Kamloops
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 10-31-2020, 09:31 AM
riseric's Avatar
riseric riseric is offline
Default +1 Aerosport Power
Yep, try Aerosport Power, my engine came from there and they were so equipped.
Eric,
2021 dues happily donated
RV-8 #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32
EarthX batteries
Aerosport IO-375
MTV-9-B/183
Skyview HDX
C-GEMQ (reserved)
Old 10-31-2020, 08:02 PM
RV-4 RV-4 is offline
Smile
Phil
Have you tried ordering them directly from the US..it might makes things a lot simpler for you..
Good luck
Bruno
