Old 06-21-2007, 04:50 PM
trib trib is offline
Question Baffled by baffling seal
I'm piecing together my baffling system on my ECI O360 on a 6A, using van's kit, but cannot find anywhere the dimensions for the seal material. The gap is to be 3/8" to 1/2" between the baffling and the cowl and sealed by the material. What is the nominal width of the material, and how much is overlapping the aluminum and how much is left to flex and seal on the cowl? My guess is it looks to be about 1" overlap on the baffling and maybe 1 1/2" to reach the cowl and seal, giving a total of about 2 1/2" width. This is purely a guess and I'm curious to see if there is any consistency between builders. How about it? Do you know what width you used?
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 06-21-2007, 05:15 PM
N908RV's Avatar
N908RV N908RV is offline
Tim, I used about 2.5" to 2.75" of width and about 1" of overlap on the baffles. 2" would probably be the bare minimum and 3" is probably a little overkill.
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 06-21-2007, 06:59 PM
lrfrey lrfrey is offline
Tim, I agree with Rob. I am in the process of doing mine as we speak and after some research those are the numbers I came up with. If we all use these numbers and are wrong....
Carry on,
Larry
Old 06-22-2007, 06:59 AM
osxuser's Avatar
osxuser osxuser is offline
You don't really need and inch of overlap on the baffle side. 1/2"-3/4" would be plenty. The more you have above the baffle, the more likely you are to seal. I would plan on using 2 1/2" with a bitt more that 1.5" above the baffle.
RV4 wing in Jig @ KPOC
RV7 emp built
