Unread 10-11-2020, 01:16 PM
Mark Jackson Mark Jackson is offline
Default Drill press & straight holes
I've ruined two WD-409 parts. I'm one to practice drilling a new hole vertically thru the mani body. I've gotten the part about finding the center line and clamping figured out but now when I try to drill through the bottom the holes wander all over.
The hole with the black mark next to it illustrates the issue. The top is dead on the center line and good. Drilling through to the bottom gies me whacky holes all off the center line.
How can I maintain the drill along a vertical line while drilling through the tube?
Click image for larger version
ID:	3303  Click image for larger version
Mark Jackson
Houston, TX
RV-8 in progress/Mooney in the hangar.
Unread 10-11-2020, 01:18 PM
R7237 R7237 is offline
Default Spot drill
Have you tried a spot drill bit to mark the hole?
And I might be wrong, but I would think drilling thru is not the right approach. I would think I would flip the part over and drill the other side,,, but maybe someone knows better than me.
Unread 10-11-2020, 01:34 PM
Bicyclops Bicyclops is offline
Wrap a piece of paper around the tube with tape so you can mark accurate holes on both sides. Center punch the holes and drill #30 or so. Then though drill the hole a little larger. I always drill undersize and ream to final size for the best bolt fit.
Ed Holyoke
Unread 10-11-2020, 02:33 PM
wirejock's Avatar
wirejock wirejock is offline
Default Drill tube
Ed Holyoke
That works. I also use a V-block. Pretty handy device for all sorts of drilling. I use it a lot. The block can be flipped around.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Unread 10-11-2020, 02:41 PM
riseric's Avatar
riseric riseric is offline
Default I used this.
https://www.aircraftspruce.com/search/search.php
works great.
ID:	3310  Click image for larger version
ID:	3311  Click image for larger version
ID:	3312  Click image for larger version
ID:	3313  Click image for larger version
Eric,
2020 dues paid
RV-8 83274
Emp & SB Wings on fuse, SB Fuselage in progress
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro & EFII Bus Manager & System 32 in progress
Aerosport IO-375 + MTV-9-B/183
Skyview HDX (next)
Unread 10-11-2020, 03:34 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Default Drill-guide V-block
https://www.browntool.com/Listview/t...ch=drill+guide
I used this when match-drilling aileron push tubes, and it worked out great. I clamped the piece(s) to be drilled to the bench, clamped the drill guide on the piece with the hole centred then drilled.
If you're drilling steel, make sure your drill speeds are correct (usually slower than for aluminium) and use lube on the bit.
RV-9, Tail Feathers done, Wings almost done.
Unread 10-11-2020, 03:40 PM
bobnoffs bobnoffs is offline
i would drill undersize holes on each side. start with a small bit and go up and pay attention to drilling your indent mark as accurate as possible. then finally drill to full size , going in one side and out the other in one pass.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
