Old 06-19-2007, 07:14 PM
N184JG N184JG is offline
Default OIL FILTER ???Catto Prop?
I just completed my ECI kit engine (IO-360) this past Saturday and need know what oil filter to buy.Also what is the torque on prop spacer bolts to the crank shaft ?
Jim Gallaway VAF#782 2013 PAID 2014 paid
Gundys airport
Owasso,Ok
RV8A N184JG FLYING SOLD
RV7 N1717G FLYING sold
Old 06-19-2007, 07:18 PM
godspeed's Avatar
godspeed godspeed is offline
Default Catto
can't help with the filter, but my catto prop has the torq settings
listed on the prop..
Danny..
Old 06-19-2007, 07:48 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Spacer
I think you're referring to the 12 holer...? Good question, I need the same answer. Of course the prop to spacer torque is on the prop.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 06-19-2007, 08:02 PM
I don't have my prop yet but do have the spacer and bolts and its installed on the engine so I could align the alt. and starter.
Gundys airport
Owasso,Ok
Old 06-19-2007, 08:23 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Have you checked the manual?
It is against male genetics but sometimes it is useful
Old 06-19-2007, 08:25 PM
N941WR's Avatar
N941WR N941WR is offline
Which spacer do you have?
The paper work that came with my Saber prop extension listed the torque values, based on the bolt size and as stated above, the torque value for the Catto prop is listed on the prop hub.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-19-2007, 08:36 PM
Default Found the info
I can fax you a copy of Saber's Doc if you would like?
12 holer extension to crank:
3/8" bolts 30-35 ft lbs
7/16" bolts 40-45 ft lbs
1/2" bolts 45-50 ft lbs
There is a step procedure 10, 20, 30 etc listed for 3/8", I don't thinks 3/8 is real common or recommended though. Also, a note about removing paraffin from the engine bolts and using Red Loctitie 262.
I would be happy to forward...
Reiley
VAF# 671
Friend of the RV-1
Old 06-19-2007, 10:04 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
My catto 3 blade prop, 66x76 is torqued at 45 ft lbs as indicated on the prop.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 06-19-2007, 10:31 PM
Walt's Avatar
Walt Walt is offline
Default Oil filter
Is the 48108-1 for the angle adapter.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-19-2007, 10:38 PM
RVadmirer RVadmirer is offline
Default Sabre Instructions
I'd be curious about the comments on removing parafin and using locktite. I was instructed to leave the parafin. Sabre didn't put it on there for any other reason than to be used.....
