Old 06-16-2007, 12:27 PM
pierre smith's Avatar
Default Propeller nuts??
My buddy has 3/8" nuts pressed into the crankshaft flange for the prop but wants to go to 7/16". Where do you buy these thingies?
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 06-16-2007, 01:44 PM
Brian Vickers Brian Vickers is offline
Default Aircraft Specialties Services
They are overhauling my crank and all the other steel parts right now. A.S.S. is also a parts supplier and I am very sure they would have the press in nuts. A web search pulls them up at the top of the list. They are very good about consulting over the phone so if you have a question it is appropriate to ask them.
Sincerely,
Brian Vickers, RV4 finishing
Old 06-16-2007, 06:53 PM
Mel's Avatar
Mel Mel is offline
Propeller flange bushings. Get them from Lycoming, Superior and probably others.
Lycoming part number for the 7/16" is 72064 and 72065. The 76065 is odd sized for indexing the flywheel.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-16-2007, 07:06 PM
Vern's Avatar
Vern Vern is offline
Default Mattituck has them as well as any other engine part you need
1-800-624-6680
http://www.mattituck.com/
Part Dept email = william_haman@teledyne.com
Prices and tech support are great!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-17-2007, 04:16 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Bushing Locations
...and to follow up on Mel's part numbers, this Lycoming SI tells you the correct locations for the bushings
http://www.lycoming.com/support/publ...fs/SI1098G.pdf
gil - presently in wet Liverpool...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-17-2007, 05:16 AM
Default Thanks..
You guys are the greatest.....thanks a lot,
Pierre
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
