Old 06-15-2007, 08:26 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Tool Question
A Unibit is great for generating holes up to 3/4" but is there an economical tool that will produce holes in thin material in the 1"-1-1/2" range? The larger Unibits require a larger drill chuck than my drill motors are fitted with. I want to install some firewall pass-throughs that require holes 1.10" in dia. What tools are available that will produce quality holes in the ranges I seek?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 06-15-2007, 08:39 AM
Vern's Avatar
Vern Vern is offline
Default Hole tools
See the aviation department cleverly disguised as electrical tools at Home Depot or Lowes. Most electrical supply houses also carry these. There are various size tools used by electricians. Cheap? No!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 06-15-2007, 08:41 AM
DaX's Avatar
DaX DaX is offline
Get a knockout punch set - Greenlee makes a good one.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 06-15-2007, 10:03 AM
Gary Bricker Gary Bricker is offline
Smile Gary Bricker
Check with Avery. They have a great hole cutter set that is that large and does a beautiful job on stainless
Old 06-15-2007, 11:27 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
I used a regular $10 bimetal hole saw to cut my heater box hole through the stainless steel firewall with no problem--left a very clean hole. Just back it up with a piece of wood or something while you're cutting it.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
