Old 06-14-2007, 05:19 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default PMA8000B audio panel back light?
I have a PS Engineering PMA8000B audio panel. The pushbuttons and marker lamps dim automatically. However, there is also an option for "unit backlighting".
The instructions say to connect to a dimmer or "if a dimmer is not used, a constant back light can be established".
The wire is already in the harness that I got from Stark. I don't plan on doing much night flying so should I -
1) not bother with this wire,
2) connect it to my panel light switch without a dimmer,
3)connect it to the same dimmer that I'm using for my Nulites,
4) put in another dimmer (like the one from Perihelion)?
Thanks.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 06-15-2007, 08:38 AM
fmarino1976 fmarino1976 is offline
Default Backlight
I would connect it to the existing dimmer you are using for the nu-lites. If you leave it unhooked, you won't be able to read the labels at night. My 0.02
Freddy
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
