Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 06-18-2007, 02:20 PM
frankh's Avatar
frankh frankh is offline
Default I had one go bad
Flying along and the intercom got dreadfully noisy aroung 100 hours....Replaced the plugs and all was well...I get them for 1.18 bucks around here.
Frank
Old 06-18-2007, 02:21 PM
Radomir's Avatar
Radomir Radomir is offline
ECI will/can do 14mm for top plugs... beefs up that boss a bit as well... not sure if it applies to angle valve stuff..
Radomir
RV-7A sold
Old 06-18-2007, 02:26 PM
dan's Avatar
dan dan is offline
I read a while back that Lycoming will be (if they're not already) offering cylinder heads with 14mm spark plug holes. I googled for it and found this: http://phx.corporate-ir.net/phoenix....783&highlight=
I think ECI might offer a 14mm option as well. http://www.eci2fly.com/exp/FAQ.aspx
I go back and forth. At times I think the 14mm cyl heads would be great, simpler, stronger, etc. Other times I think the 18mm setup is most versatile and doesn't close any doors.
Dan Checkoway RV-7
Old 06-18-2007, 08:08 PM
frankh's Avatar
Default Just a thought
Does one need the 18mm hole for borescope inspections or is the probe small enough to get in through a 14mm hole?
Frank
Old 06-21-2007, 07:49 AM
SFB711 SFB711 is offline
60 hrs on a set of .035 gapped champions and all look great with two p mags running 25 degree timing and a mix of auto and 100LL.
Old 10-02-2009, 12:19 PM
molson309 molson309 is offline
My apologies for resurrecting an old thread, but I think this is useful information for those running automotive plugs:
If your radio starts getting ignition noise, make sure you clean and put a light amount of dielectric grease on the plugs/inside boots. Thinking it was the plugs that were at fault, I was replacing them every 100 hours - since I used dielectric grease the problem has not recurred, even with several hundred hours on the (now iridium) plugs. At annual I clean and regrease them, even though the noise in the radios is still not present.
Old 10-02-2009, 03:02 PM
frankh's Avatar
Default good point
I did use the dielectric grease and it seems to work
Frank
Old 10-03-2009, 10:50 AM
pat pat is offline
Location: Midland, Michigan 3BS Hanger 4B and sometimes at home
Default 14mm
My ECI parallel IO360 has 14mm all the way around. Its an option with ECI.
Patrick Howe
Citabria 7KCAB - sold
RV8A FB - flying
