Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 07-27-2020, 10:30 AM
SteveR SteveR is offline
Default What 13" spinner kit should I buy for an IO-360 & Prince Prop
Van's sells a 13" Fixed pitch spinner kit for Wooden props, part number: SPINNER, FP-13
https://shop.vansaircraft.com/cgi-bi...roduct=spinner
Will the FP-13 spinner kit work for a Prince carbon/wood prop? The prop is 3-3/4" thick.
I want to make sure the front bulkhead will mate properly with the spinner without modification using a prop of this thickness.
Old 07-27-2020, 10:42 AM
rvbuilder2002's Avatar
In the past when wood props were far more popular, there was no universally accept standard hub thickness adopted by all of the different prop makers. It seemed they all just did what the wanted and then builders had to make a spacer of the appropriate thickness (if needed) to put the fwd bulkhead at the proper position.
I am not aware of any situation where the prop was too thick for the Vans standard fixed pitch spinner.
Scott McDaniels
Hubbard, Oregon
