Old 07-25-2020, 11:09 AM
Delta Bravo Delta Bravo is offline
Default Interesting Tru Trak failure.
My Vizion 385R started tripping off intermittently in flight especially in turbulence. Since it is several years out of warranty I broke the factory seal and opened it up to find a screw bouncing around the circuit boards causing the failure. The screw certainly came from the top right of the photo presumably to hold that portion of the front circuit board/display in place however unlike the left side no washer had been used. I then noticed a repurposed rubber grommet wedged between 2 boards applying pressure to help hold the forward Board/display under tension.
Deciding weather to find a suitable nylon washer to replicate the left side and replace the screw. Will probably take a friends advice and leave it out.
https://www.dropbox.com/s/1120da760x...F8014.JPG?dl=0
