Old 07-24-2020, 10:45 AM
gdrudolph gdrudolph is offline
Default Continental CD-265 Jet-A Engine
A friend I work with, Guil, enlightened me to this engine and I have fallen in love with it!! Anyone know of any Vans certification progress from Continental or Vans on this front?
http://www.continental.aero/diesel/engines/cd200.aspx
Cheaper gas cost
Turbo
4 cylinder
265 HP
11.7 gal/hr. burn
Hoping Garmin integration for emergency land feature (a feature that would help me sell my build to the CEO of our household).
The CD-230 to CDR-285 is a family of four-stroke 4-cylinder, air/oil-cooled, horizontally opposed, direct-drive piston aircraft engines with turbocharger and direct injection. The engine has a maximum continuous power of 265 HP @ 2500 RPM
Neophyte RV-10 (to be started)
Private Pilots License 1987
25 Year flying hiatus to raise 3 kids
and now the flying "itch" is back!
Old 07-24-2020, 01:12 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Would be interesting to know at what hp the 11.7 gph FF figure is obtained at and of course the cost of the engine.
Looks nice and the weight isn't too bad if that's with accessories.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.7 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 07-24-2020, 01:45 PM
rmartingt's Avatar
I don't think it's exactly the same engine but you might find these threads of interest...
https://vansairforce.com/community/s...d.php?t=148800
https://vansairforce.com/community/s...d.php?t=172550
RV-7ER - finishing kit and systems installation
Old 07-24-2020, 02:16 PM
unfortunately, still needs accessories ... so ... more weight but I don't know how much...
Old 07-24-2020, 06:34 PM
Flandy10 Flandy10 is offline
Default CD-230/265
This is/will be the engine I have. It is also an older spec sheet.
I know more than I'm allowed to say about it, but I do love it. I don't know/can't say when it will be ready for delivery. Vans knows about this project but they are keeping their interest level to themselves as they have not spoken to me about it... EVER.
The quoted FF is about 225HP. The engine can cruise at 90%power all day long. The weight is for the engine only- but that does include the primary exhaust system.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
2020 VAF Donation complete
Old 07-24-2020, 07:34 PM
Oh man... THANKS SO MUCH!!! There is hope I have not even started... YET haha. So I'm a good 3 -5 years out. It is GREAT because Vans just announced 'final size holes' so no "rinse and repeat 3x" as Jason says on his youtube channel haha. This announcement has made me even more eager to start. In any event, I'll keep an eye on your build blog if you have one... and mums the word
Old 07-25-2020, 06:54 AM
sailvi767 sailvi767 is offline
It looks like a great option but it is heavy. I also wonder about pricing. Past attempts at jet A piston engines have had eye watering prices.
Old 07-25-2020, 08:28 AM
lr172 lr172 is online now
That is pretty exciting if it is accurate. I cruise LOP around 11 GPH and if I believe the common stats, I am producing around 165 HP at that flow. If this diesel can produce 215-220 HP at that same flow, WOW that is an impressive boost.
Everything I have read from Ross seems to indicate similar BSFC / efficiency stats between the std Lyc's and the new diesels, so I remain somewhat skeptical.
Larry
Old 07-25-2020, 10:09 AM
rv6ejguy's Avatar
11.7 gph at 225 hp is a BSFC of .34. We're seeing figures of around .38 with 9 to 1 Lycomings running LOP with EFI and EI. So that's about 10% better for the diesel in cruise. So you'd have to see what the weight and cost trade offs would be.
Old 07-25-2020, 10:20 AM
The weight is close to what the O-470 on my C180 weighs, but the power and fuel consumption is a bit higher. It's probably a reasonable engine for an RV-10 or Rocket, but would someone please explain why this would be preferable to a Lycoming IO-540 that you can buy today and which has known service requirements and reliability and for which the aircraft are designed?
I just don't see any advantage to this thing. Anyone?
Dave
