Old 06-11-2007, 02:12 PM
pierre smith's Avatar
Default Aeroshell 100W shelf life?
Hi Guys,
I have a couple of cases of 10 year old Aeroshell 100W and wondered if it has a shelf life. Is there any reason to not use it in my 0-360? The plastic containers have always been under roof in my hangar in the original box.
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 06-11-2007, 02:20 PM
Mel's Avatar
Mel Mel is offline
I had a Shell rep tell me that the shelf life is quoted at 5 years. But that is mostly a "CYA" thing. He told me that unless there are some kind of contributing factors there shouldn't be a problem with it. I have used AeroShell that was 10 years old. I would not be afraid of using it.
On the other hand, It is expired so if you will send it to me, I will dispose of it for you.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-11-2007, 03:34 PM
Default Big heart!!
You're all heart, Mel..... I agree that it's a CYA thing......
Pierre
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 06-11-2007, 09:09 PM
mannanj's Avatar
mannanj mannanj is offline
Default Shelf Life
Pierre:
How long ago did that dinasaur donate it's life to enable you to have that oil?
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 06-12-2007, 12:24 AM
osxuser's Avatar
osxuser osxuser is offline
This may sound stupid, but what I usually do with older oil is use it one quart per change, that way if there is a risk, it's diluted 7:1.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-12-2007, 08:24 AM
fly5465 fly5465 is offline
Pierre,
I asked this same question to Shell a while back. Here was their reply to me.
"Dale - shelf life on AeroShell piston engine oils is 4 years from date of manufacture. The cases you have are dated January 25th and March 25th of 1999 (MMDDY format for the date stamp after the letters WR).
I would recommend you not use the product. The biggest issue you face with out of date product is that the additives tend to "drop out" due to gravity, and once that happens you cannot properly re-mix them, even with vigorous shaking.
Sorry for the bad news, but again I cannot recommend use of this product in your aircraft."
END OF QUOTE.
I agree with OXSUSER, it probably wont hurt to add one per change.
Dale - FFZ,AZ
Dale
Mesa, AZ
RV6A-QB in progress
Old 06-12-2007, 08:44 AM
captainron's Avatar
captainron captainron is offline
I'm thinking that the rotating and reciprocating internal engine parts the can "re-mix" those additives.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 06-12-2007, 06:33 PM
RV7ator RV7ator is offline
Couple months ago I asked Ben Vissar (sp?), a columnist with General Aviations News and a Shell Oil retiree, this very question. I was getting near the bottom of the barrel of Phillips 20W-50 that was upwards of ten years old. My concern was shelf life because I occasionally see darker, precipitate-like fluid in the last dribbles from quart bottles of Aeroshell W100 that are less than two years old.
His reply is that av oil must meet all performance specifications up to three years on the shelf. No comment on how different oils may change beyond that, but the tone was no worries.
Still, what about that Aeroshell discoloration I see and the comment above?
Engines make good blenders unless it's a chemical deterioration. Any one have the answer?
John Siebold
Boise, ID
Old 06-12-2007, 09:41 PM
Low Pass's Avatar
Low Pass Low Pass is offline
kept clean, dry, sealed... I'd say 50-100 million years, give or take a couple.
Bryan
Houston
Old 06-13-2007, 05:17 AM
captainron's Avatar
Maybe this is what is meant by "rotate stock". You could flip your unused cases upside down every few months.
Ron Leach
Cincinnati
.....Bob Seger
