Originally Posted by rv8ch
There is a lot of air pressure there. If you can push this down gently with your finger, it will go down due to the air pressure.
Mickey, how do you know?
Note I don't
know either. However, if we're spitballing, I'd make four points.
One, at high AOA, as in climb, that particular spot may be subject to separated flow. Since it is the left inlet, separation may be exacerbated by prop outflow (rising blade). Point is, there may not be much local dynamic or static pressure just aft of the lip.
Two, the gap will get larger as the rubber mounts age and sag.
Three, engine torque reaction will widen the static gap.
Four, even in level flight a significant step drop off is not a good thing.
Anyway, it's not hard to improve it. Bend a flange on a length of aluminum strip, and insert it between the glass and the rubber.
