Old 06-09-2007, 05:27 PM
Jim P's Avatar
Jim P Jim P is offline
Default Oil Supply Line Fitting Problem
I have an IO-360-M1 with C/S and there's an issue with the Van's oil cooler supply line clearing the constant speed control cable bracket.
Per Dan's website, he went with the 45-deg. engine fitting and a 45-deg hose fitting for the oil supply line to the cooler. Has anyone used straight fittings here and actually have it work?
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 06-09-2007, 08:14 PM
frankh's Avatar
frankh frankh is offline
Default Even a 45 wouldn't work
with the straight back style of oil filter adaptor (already had a stright end fitting on the hose)....Incidently nor would a stright, or 90 deg.
I had to weld a 45 deg on the end of a straight at about a total angle of 60 deg...
Phew!
Frank 7a
