06-29-2020, 08:55 AM
Originally Posted by Taltruda
I don't like that he put in a date for the next required CI..a CI isn't required at all.. it's only required to be done within 12 months of a flight, so what if you parked the plane for 5 years and exceeded his date that he wrote in?
Simple—You complete a condition inspection, make the appropriate log entries then go fly. It’s the same for standard certificated aircraft that are out of annual. Putting a date down doesn’t do anything other than serve as a reminder because if you go past the 12 months the plane is technically grounded whether there was a date there or not. IOW when you do the inspection, early, on-time, or late isn’t driven by logging the next due date.
Personally I don’t put a date in my log, but I do keep a sheet in my POH that lists all my next inspection dates (condition, pitot/static, and transponder), plus my next oil change, and ELT & main battery replacement dates.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
06-29-2020, 11:42 AM
Originally Posted by Auburntsts
Simple?You complete a condition inspection, make the appropriate log entries then go fly. It?s the same for standard certificated aircraft that are out of annual. Putting a date down doesn?t do anything other than serve as a reminder because if you go past the 12 months the plane is technically grounded whether there was a date there or not. IOW when you do the inspection, early, on-time, or late isn?t driven by logging the next due date.
Personally I don?t put a date in my log, but I do keep a sheet in my POH that lists all my next inspection dates (condition, pitot/static, and transponder), plus my next oil change, and ELT & main battery replacement dates.
Exactly.. I understand and agree with what you said. I was just trying to state that it's silly to have a "required by" date written in the book. Sure, it's a good reminder to put on your calendar, but not in the logbook. .
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
06-29-2020, 12:12 PM
Originally Posted by mturnerb
The precise wording should also be in your operating limitations....
He won't have a legal set of Operating Limitations for his plane until the FAA Inspection.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
06-29-2020, 12:58 PM
My guess is that Gil was paraphrasing. I don't think an inspector would use the words "required by" under these circumstances. The correct terminology would be "due".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
06-29-2020, 01:47 PM
My mistake - I was thinking of entry after Phase I.
06-29-2020, 01:48 PM
Originally Posted by Mel
When I do an inspection, I include a sticker with the builder certification wording if you don't already have it. Then after inspection is passed, I add:
"I find that this aircraft, N1234, meets the requirements for a special airworthiness certificate for the purpose of Operating Amateur-Built Aircraft and have issued a special airworthiness certificate dated ________________. The next inspection is due __________________."
Signed:____________________________ DAR _______________
Well, I went back to look at mine, and sure enough, it had the "next inspection is due on" words. That's the last time that phrase appears in my logs, as I never put down anything more than is *required* by the FAA to complete the annual CI.
Why anyone would add more than what is required, I dunno...the amateur lawyer in me says don't do that, but that's just my opinion.
2019 Dues paid!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
