Originally Posted by RV7AAAAAAA
Are you sure this is a clutch? I always thought it came to the end of the threads and just spun.
Jim and Frank, you're right, there's no clutch in there, I just confirmed it with Van's. I made an erroneous assumption here, yikes! Now I need to either put in a limit switch or change the geometry of the mounts to coincide with the full travel of the actuator. Frank, my apologies to Dick for leading him down a bad path. Dang, I screwed this up!
