Old 06-20-2020, 05:18 PM
Pilot8 Pilot8 is offline
Default RV8 throttle travel shrinking
A new throttle cable from Van's has 2 1/8" travel- over time the travel will decrease by 3/8" on my IO360-M1B RV8. The throttle cable is firesleeved from the fuel servo end to the engine mount. Aluminum fiberglass tape wraps the firesleeve, and exhaust heat shields protect the cable at the crossover spots. The cable travel doesn't get any shorter after 3/8 is lost- at 50 hours, 1/4" of travel is gone. It's been repeatable with two cables. Anybody else seen this issue? 3/8" is a lot of horsepower!
Thanks!
Old 06-20-2020, 05:36 PM
ILikePike ILikePike is offline
Same setup. Start with plenty of free play. Use a shorter throttle arm if you have to for full travel. I drilled a new hole 3/8" in from factory hole. The green cables in the kit were not the best length. Replaced with Cablecraft high temperature cables. T-61", G-48.5", M-51"
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 06-20-2020, 05:51 PM
Where did you buy the cablecraft cables?
Old 06-20-2020, 06:33 PM
sapeloson's Avatar
sapeloson sapeloson is offline
Default Second on the new hole.........
I thought I had checked everything prior to my DAR inspection. I missed the "full" movement on the throttle arm. When Vic found it he said, "easy fix, drill a new hole"..... I had it moving full travel in just a few minutes.....
RV-8 N84TH
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
C-182 N3159F
Old 06-20-2020, 11:53 PM
scsmith scsmith is offline
Default McFarlane custom cables!
My recommendation is to spend the extra money and get custom McFarlane cables. you will not regret it ever.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 06-21-2020, 12:56 AM
jliltd's Avatar
jliltd jliltd is offline
McFarlane really is the best. And is priced accordingly. I just installed one of their vernier assist mixture controls in my RV-3B and it is the bomb. Very high quality.
Jim Ivey
RV-8
(and a few more airplanes)
Old 06-21-2020, 08:01 AM
Great tip on the McFarlane cables, thanks guys!
