Old 06-06-2007, 07:58 PM
tcone1's Avatar
tcone1 tcone1 is offline
Default wingtip rib question
Hey there,
I'm finishing the wingtips on my -8. Part number W-412 is the wingtip rib at the trailing edge. The plans call for the flange to face inboard, toward the aileron. I've heard people then fill the opening of the wingtip, so that it is smooth.
My question is, rather than doing it that way, why not put the flange facing outboard. I realize that the rivets will be tougher to buck, but I'm going to over-countersink them and glass them over anyway and might just use pulled rivets and epoxy.
The real question is can I get away with reversing the flange orientation?
Tim Cone
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 06-06-2007, 08:06 PM
The answer is that sure, you can reverse the rib.
Building it the way the plans show will result in the lightest, easiest to build (i.e. fastest) method, but if you want to reverse it, that's doable.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-06-2007, 09:16 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default Aileron Bracket
Just be sure that the outboard aileron bracket fits when you reverse the rib. I filled mine then had to dig it out slightly to make room for it.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 06-06-2007, 10:38 PM
GAHco's Avatar
GAHco GAHco is offline
Default Fliipin rib
Will that mess with the wing tip mounting?
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 06-07-2007, 07:40 AM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
Sorry to dumb down the thread but I'm just starting my wings and looking forward a bit. So what "opening in the wingtip that people fill" do you mean??
Just trying to glean as much wisdom early enough to decide how I want to build mine.
Grant
Old 06-07-2007, 08:51 AM
tcone1's Avatar
Default not dumbing down
I have seen airplanes that people filled the flanged recesses in the ends of their ailerons, tips and flaps. I don't know if it helps drag-wise or not.
Timothy Cone
RV-8, XP360, RV200
Old 06-07-2007, 09:22 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Filling
Hi Tim,
I filled mine by putting the metal rib in as indicated on the plans. I then filled with 1/2" foam using epoxy and microfiller to secure. The outer area was glassed with 2 layers of cloth.
As someone noted, you have to work around the last couple of screw holes for the tip attachment.
Does it do anything? Couldn't tell you but it looks cool and maybe added 3-4 oz per side.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
