Old 06-17-2020, 09:24 PM
Aero_Octaveus Aero_Octaveus is offline
Default Edge distance issues at firewall
Has anyone else had edge distance issues on the topmost hole of the side skin F-770 where the AD3 rivet attaches to the firewall flange. I haven't drilled mine yet, but it really looks like i'm going to blow the edge distance here and I cannot for the life of me figure out how to get more distance.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2021 Donation Current
http://garetsrv.blogspot.ca/
Old 06-17-2020, 09:42 PM
wirejock's Avatar
wirejock wirejock is offline
Yep. Mine are close as well. One each side. It's barely within edge distance tolerance. I never called Vans because I figured edge distance was different for stainless. Vans designed it so they must know about it. Let us know if you find out otherwise. No way to change it except a doubler or extra rivet each side.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 06-18-2020, 09:48 AM
Thanks Larry, yup I called Van's today and it was a 'build on'. We are so ingrained to be mindful of edge distance through the build that when we hit an area like this, the panic starts to set in.
