Old 06-18-2020, 03:48 AM
cderk's Avatar
cderk cderk is offline
Originally Posted by bkervaski View Post
Both displays or just one?
@togaflyer's was some kind of issue that affected both at the same time, doesn't sound related.
It?s mostly my PFD, but has happened on the MFD as well. Like I said, it doesn?t stop responding to touch... you just have to touch it in a number of places until it registers correctly. I guess the sensors are around the perimeter of the panel. I need to get another can of compressed air and really try to blow dust out to see if that will improve things.
RV10
http://n688cd.wordpress.com
Old 06-18-2020, 05:25 AM
TJCF16's Avatar
TJCF16 TJCF16 is offline
I had myMFD freeze up with red X?s and auto pilot flags went off but it stayed engaged! Reset on the ground! Garmin said it was a 232 problem on the can bus connection to the MFD. Found no issues has not repeated its self. Pad worked great!
Tim Crouch
RV-9A N626TC
"Merlin"
Old 06-18-2020, 12:48 PM
togaflyer togaflyer is offline
Never had any Xs. Both screens just froze. Keep in mind all the attitude and heading info continued to function normally so I did not have a flight safety issue. The GTN 650 did its work and had comm 1 available. I was not able to do anything with my transponder or comm two which are both remotely operated. The transponder continued to work, but if requested I was unable to change the squawk code. Just any touch commands went off line, Weird? I sent the logs to Garmin for their review. Note: this system has functioned flawlessly for 2.5 years. So not concerned unless I get a repeat. But this is the reason for a backup that does not run the same software. The G5 has its own and along with Garmin Pilot on my mini I pad It gives redundancy for situations like this, no matter how rare of an occurrence.
