Old 06-06-2007, 10:18 AM
rv9builder rv9builder is offline
Default Aligning RV-7A or 9A brake Pedals
How far are the brake pedals supposed to be tilted forward? What do you use as a reference point?
Thank you,
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 06-06-2007, 10:43 AM
kentb's Avatar
kentb kentb is offline
Default I assume you mean the brake pedals.
I put my rudder bars in the plane and set in my normal position. Then I made sure that the angle of my foot would not be pressing on the brakes. During final installation make your linkage for the rudder cable so that pressing full deflection and full brake will not touch the firewall or any hardware attached to it.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 06-06-2007, 11:24 AM
Oooops! You're right, Kent. I meant brake pedals, so I edited my original post. Thank you for your reply. I like your idea of how to set up the pedals.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
Old 06-06-2007, 01:02 PM
pierre smith's Avatar
Default Also this......
Mark,
If you have big feet, size 11 or 12, also consider raising the blocks on the longerons another inch with a plastic block. It helps with inadvertent brake use. We placed a ruler on the back side of the rudder pedals and then brought the brake pedals back to touch it, which gives them a little lean back away from your feet.
Pierre
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 06-06-2007, 01:44 PM
Norman CYYJ Norman CYYJ is offline
I used the standard holes in the longeron, and I have big feet. I consider size 11-12 small feet. Use the above suggestions for the link length, all will work out well. When the brakes are depressed they only pivot forward about 3/4 an inch at the most with maximum braking.
Old 06-06-2007, 01:55 PM
wingtime's Avatar
wingtime wingtime is offline
Default yard stick
I did pretty much the same thing Pierre did. I took a metal yard stick and clamped it to the rudder pedals (all 4 of them). This lined up the rudder peddels. Then I just tilted the brake pedals back against the yard stick and drilled them. This gave the brake pedals a slight forward tilt, just enough so my feet wont touch them with them on the rudders only.
Bruce Smith
Clearwater, FL
RV-7A Fuse
N27DB reserved
web.tampabay.rr.com/flrv7a
"Political correctness is tyranny with manners."
Charlton Heston
