Old 06-04-2007, 09:54 PM
Davepar's Avatar
Davepar Davepar is offline
Default Lesson learned on wiring a GNS-430W
I'll throw out this tidbit so it can help someone else. When I wired up my avionics, I had one serial output from the GNS-430W go to my autopilot and a separate serial output go to the EFIS. I thought that would give me the most flexibility. Turns out both the EFIS and autopilot want the same "aviation" format. The 430W can only output a particular format on one serial output. I'll have to do a little re-wiring.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 06-04-2007, 10:41 PM
MCA's Avatar
MCA MCA is offline
Dave, same issue here with the regular G430. And the 300XL, 480 and GRT EFIS that I know about.
Marc
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 06-05-2007, 06:03 AM
Ironflight's Avatar
VAF Moderator / Line Boy
At least it's an easy fix - you just split the output to go two places - I think I discovered the same thing the hard way when I did mine....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-05-2007, 07:05 AM
w1curtis's Avatar
w1curtis w1curtis is offline
Yup, I'm feeding three (3) devices with one GNS-430 serial out port. See here.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 06-05-2007, 09:04 AM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default Garmin has been promising to fix this for three years
that I know of. It seems that this is a software issue that aviation output can only be on one of the four serial outputs.
I assumed that the GNS-430W would include the fix but apparently it has not.
bruce
N297NW
RV-8 (449 TT)
Old 06-05-2007, 12:22 PM
w1curtis's Avatar
bruce
N297NW
RV-8 (449 TT)
I guess I don't see the problem and Garmin probably does not either-which is why they have not changed it. If you have "Aviation Out" on one port and this can be wired to multiple devices, the inability to set "Aviation Out" on additional ports become a non-issue.
I think builders should stop thinking of the GNS-400/500 serial out ports as discrete ports and more like a data buss. Then it is simply a matter of turning on the required data on a bus and then attaching devices that require that data to the bus.
I can't think of any scenario that an additional "Aviation Out" setting on a separate port would make things easier/simpler.
William Curtis
Old 06-05-2007, 12:43 PM
dan's Avatar
dan dan is offline
Excellent advice imho! (another who learned this the hard way with my GX60)
Dan Checkoway RV-7
Old 06-06-2007, 12:00 PM
MCA's Avatar
MCA MCA is offline
It's been a while, but I don't remember that the manuals spell this limitation out clearly. If you are aware of it up front, not an issue. If the panel is installed and wired, and then you go to set up the data ports, it's an issue. Don't ask me how I know.
Marc Ausman
