Old 06-04-2007, 06:20 PM
Rivethead Rivethead is offline
Default Pressure transducer question
I have two Stewart Warner transducers that look identical. I know one is for oil pressure and the other is for fuel pressure. As I'm looking at them I see on the threaded end that screws to the firewall mounted manifold for pressure transducers that one has a 100 stamped on it and the other a 60 stamped on it. My logic is telling me that the 100 is oil pressure and the 60 is fuel pressure (my engine is injected). Can someone tell me if my assumption is correct or not?
Old 06-04-2007, 07:57 PM
Radomir's Avatar
Radomir Radomir is offline
that sounds right.. those should be 100psi and 60psi..
Radomir
RV-7A sold
