06-09-2020, 08:10 AM
Originally Posted by 9GT
I got the same ones in 8 x 8 for the small bits and also 4 x 6 for larger bits. Drawers slide in and out easily. So far, I only have two of the 8 x 8's and 2 of the 4 x 6's. More to come I am sure.
06-09-2020, 11:49 AM
I have a bunch of the harbor freight storage boxes which are similar to the one Bobby is showing. Its nice to be able to remove a bin with rivets of only one size at a time. If you knock over a bin its not too bad, but if you have a drawer with mixed sizes then its a sorting nightmare.
They go on sale for $3.99 each but normally they are only $5.99 each. I mark on the side of the bin the part number or description with a highlighter.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
06-09-2020, 01:57 PM
If its anything like the -8, you'll get all the rivets, nuts, bolts, screws and washers that come in the tail kit sorted out in time to then reorganize everything that comes in the wing kit.
If you sort everything into little bins, you might as well get a couple of hundred small ziplock bags, like the ones used by crafters (for beads glitter and such). Because, all it will take is one little slip and your sorted and organized bin full of a dozen different sizes of rivets will be scattered to the four corners of your shop. At least if everything is in ziplock bags, you won't have to break out the rivet guage to individually re-sort every rivet.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
06-09-2020, 02:16 PM
i tried to organize rivets but gave up. i leave them in the bags (and mark the length on the tag they come with) except the an426ad3-3 and -3.5 since they come in paper bags. those got moved to plastic ice cream containers. i use the lid to dole out a few rivets and put the rest of the container where i can't knock it over. you use pretty much 4 sizes commonly and the rest sparingly. the bags are nice since they generally don't shoot rivets everywhere like a container.
rivets are kept in 4 boxes: 470ad4, 470ad3, 426ad4, 426ad3.
i haven't found any real advantage to organizing bolts other than by diameter since i double check them with a gauge anyways. i just leave them in the original bags.
the rest of the misc hardware either stays in the bag (and i use the packing list to find) or in one of those HF containers. the only thing that i've found really worth being careful about are nut plates. it's far easier to sort and split them during counting than assembly.
06-10-2020, 08:40 AM
I keep a lot of the parts organized in the bags they come in - since I went with QB fuselage and wings, I may have fewer total parts than someone who is doing the whole thing. I've gotten pretty good at scanning the inventory lists for which bag is which. I moved some rivets and bolts to a few 64 (8x8) drawer boxes, but I'm always afraid that a good bump on the box or table will result in a huge mess, like the time I asked my son to grab 4 rivets and he dumped a drawer of about 500 all over the place.
Dave Paule shared a great idea with me - save those small 4 and 8 ounce water plastic water bottles that tend to pile up over time or dominate our landfills and store rivets in them.
The bottles have a small opening - a tip or drop won't lose too many contents and the bottles tend to be really tough. Even dropping one full of rivets on a concrete floor rarely cracks the bottle. And the plastic bottles tend not to scratch aluminum, so you can rest a full bottle pretty much anywhere while working.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Tail finished March 2020
Wings finished July 2020
Fuselage joined to tailcone on July 19, 2020
N1814T reserved with FAA
Donated through 12/31/2020, EAA and AOPA member
When it absolutely, positively doesn't matter when or if it ever gets there, ship with Old Dominion.
06-10-2020, 09:50 AM
I just did inventory for my new build (with QB wings and fuselage) and took the opposite approach, because in my last build it drove me crazy looking for parts in little bags everywhere and scanning the inventory sheets to find the right bag. This time I organized parts by type like nutplates, washers etc. - carefully labeling compartments with part numbers. Only time will tell if this is a better approach. I did store a few "specialized" bags by bag number, like those with parts for stall warning and fuel selector.
It always amuses me (sometimes frustrates me) how Van's can spread a large number of the same part over a bunch of little bags. I know that it makes it easier to build up various kits for different aircraft but it can get tiresome finding yet another handful of AN3-5 bolts or 3-3.5 rivets. There was even one bag (fortunately very small) that mixed 3-3.5 and 3-4 rivets. No way I'm going to sort those. Fortunately I have a bunch of extras in both sizes so I just tossed em.
06-10-2020, 04:07 PM
Unfortunately the two are not compatible, though. The HF bins are too tall for the other style (Home Depot?) Tried to customize the size/type bins in each case, but that idea didn't work out. Both seemed to be good for the job.
I am afraid of dropping the cases (though all should be OK if the lid stays shut), but do like seeing the all parts and their names all together as a good memory aid.
06-10-2020, 04:19 PM
I keep a lot of the parts organized in the bags they come in - since I went with QB fuselage and wings, I may have fewer total parts than someone who is doing the whole thing. I've gotten pretty good at scanning the inventory lists for which bag is which. ...
I have a rule, if I touch the paper bag, it's contents gets sorted and stored by part number and crossed off the inventory sheet. Nothing is more frustrating to me than to repeatedly search that danged computer printout from Van's, to find out which little paper bag that standard piece of AN hardware is stored in.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
06-10-2020, 05:31 PM
Mentor
<snip>
Amazing all the stuff I learned and continue to learn from Mentor Dave. The bottle thing was one of the first tips he shared. I did separate 426 and 470 into baskets but they are still living in those bottles. I pour out a few into a paper bowl for rivet work. The size is jotted down in the bowl with a marker.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
06-10-2020, 11:06 PM
Brace yourself for the firewall forward. I bought a set of common AN-3 and -4 bolts, which came with washers and stop nuts. But I also bought many sizes of adel clamps and metal stop nuts, and a set of cotter pins in assorted sizes. I also got panel nuts, screws in assorted sizes (4-40 are handy for some things), and on and on. I got a fancy tackle organizer to manage electrical connectors and pins, plus the top section is great for storing special electrical tools. The Vans kit gives you an airframe, but there is so much more you will get before the aircraft is flying.
EAA Technical Counselor #5357
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
