Originally Posted by Mich48041
Bob N's diagrams have two current paths supplying power to the E-Bus, one
through a diode and one through a relay (or switch). Eliminating one of those
paths greatly reduces the reliability of the E-Bus. Relays are much more likely
to fail than a diode.
I don't think this idea qualifies as "eliminating one of those paths." It still provides two possible paths to power the E-bus, just like Bob's diagrams. The primary difference is that the alt feed switch in Bob's diagram is
additive - closing that switch connects the second feed to the E-bus but does not disconnect the feed from the main bus.
The comment on failure probability for a relay vs diode is good info, thank you - and it fits with my gut feeling, if for no other reason than just comparing solid state vs mechanical parts.
Lots of good discussion here.
