  #11
Old 05-20-2020, 10:22 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by PaulvS View Post
There was a recent post on here, sorry can't seem to find it now, but someone redid his panel using the metal from a road sign. Don't know where or how he got the road sign though...
That's a great idea and I have a whole mess of new signs I bought at a city auction, thanks !!
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 05-21-2020, 02:59 AM
74-07 74-07 is offline
I just ordered one and had Bill at Up North Aviation design and cut it for me. I was surprised in talking to Vans to learn that there are actually two different panels for the 8. Earlier airplane panels are slightly different than the later planes. Just be certain you're ordering the correct one. Vans used my kit serial number just to be sure I was getting the correct panel.
Old 05-21-2020, 09:15 AM
Pilot135pd's Avatar
Good catch, yet another reason to call to place an order instead of using their website.
Old 05-21-2020, 09:22 AM
terrye terrye is offline
Default Use of commercial aluminum in panel
Originally Posted by sjjonesnz View Post
Hi all, I'm looking to take the opportunity of tidying up some things on my panel when I do upgrade my transponder for ADSB (replacing my GTX327 with a GTX335)
0.063" 2024T3 alclad isn't cheap so I'm considering using a more readily available and so better priced commercial grade, say 5005.
Thoughts?
I agree with fl-mike, 6061-T6 would be my second choice after 2024-T3. It's nearly as strong and machines/cuts well.
My experience with 5XXX alloys is that they are very "gummy" to cut or machine as well as being less strong. Whichever you choose, get a small sample and drill some holes, use a hole saw, file, etc. and make sure you're satisfied before buying an complete panel blank.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 05-21-2020, 10:39 AM
krwalsh krwalsh is offline
Default 7000 Series
Beware that most road signs are made from 7000 series aluminum, specifically 7075. You will not be able to bend it without cracking it unless it is annealed to -0 temper. Wonderfully strong stuff, but not easy to work with.
Kevin R. Walsh
Cozy Mk-IV
Old 05-21-2020, 11:12 AM
Pilot135pd's Avatar
Why would I need to bend it? Seems like mine is just a flat surface. I did notice a small bend on the bottom, I suppose to give it rigidity, but that wouldn't seem to be an issue with the sign since it's very rigid already. Then again I'm not a builder so there might be something I'm missing.
Old 05-21-2020, 11:22 AM
Ironflight's Avatar
VAF Moderator / Line Boy
If you have a stock panel, then there is a 90 degree bent lip on the bottom - that?s a pretty significant bend! It?s there to make the panel stiff. If you don't - then Someone has already been in the custom business on your bird....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-21-2020, 11:24 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
don?t know about other models, but remember something stating the panel on the -4 as structural...
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 05-21-2020, 11:25 AM
Pilot135pd's Avatar
If you have a stock panel, then there is a 90 degree bent lip on the bottom - that’s a pretty significant bend! It’s there to make the panel stiff. If you don't - then Someone has already been in the custom business on your bird....
Yes, I mentioned the bend and stiffness so good to know we're on the same page and I'm learning here.
Old 05-21-2020, 11:26 AM
Mel's Avatar
Mel Mel is offline
You can always rivet a piece of 3/4 X 3/4 X .063 angle to the bottom.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
