  #51
Old 06-14-2020, 12:21 PM
ChuckC ChuckC is offline
The wires coming out of the new trim motor are: ORN, GRN, BLU, WHT AND BLK. The wiring harness, P30, to power the trim motor, has wires colored: WHT/ORN, WHT/GRN, WHT/BLU, WHT, WHT. So which WHT, WHT goes into the D-sub connection holes 4 and 5? Or, does it make any difference?
Chuck Carlson
120445
Old 06-14-2020, 03:23 PM
Bob Y Bob Y is offline
ORN to WHT/ORN, GRN to WHT/GRN, BLU to WHT/BLU. As to the two white wires, yes, it makes a difference. Before setting the male pins in the D-sub, I temporarily inserted all of them in the female side to confirm the actuator was moving in the correct direction before inserting them into the connector. Just look at your EFIS and verify trim up button causes the display to move trim up.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Old 06-14-2020, 05:58 PM
Mich48041 Mich48041 is online now
The display should show the AST position no matter what, even if the motor is run with a 9 volt battery.
Joe Gores
RV-12 Flying
Old 06-15-2020, 09:50 AM
Here is the quick response I got from Tony Kirk at Van's:
Good morning Chuck,
Yes, it will make a difference which white wire is connected to the black wire. See the latest KAI section 11iS/U?08.
https://www.vansaircraft.com/service...isions/11is-u/
The two white wires in the original harness change polarity based on the position of the trim switch. If your trim is running opposite of the direction it should run, switch the wires in pins 4 & 5.
Test the trim motor for proper function by following the steps in Section G2 of the Production Acceptance Procedures (PAP).
https://www.vansaircraft.com/wp-cont...V-12iS-PAP.pdf
Chuck Carlson
120445
Old 06-17-2020, 11:20 AM
rcarsey rcarsey is offline
I just wired this yesterday. Yes, it looks like two white wires.. but the one with the black stripe has a very very light "D" written on it instead of a stripe. No guarantees that that's the same wire you picked as black at the db9 connector connected to the power distribution pc-board.
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Tail 100% done
Wings 95% done (AOA)
Fuse 100% done
Finish 100% done (cowl)
Avionics 100% done
Dues paid 2019
