05-15-2020, 04:57 PM
Originally Posted by AeroDog
Reading the document, it appears that the "low cost" replacement motor for those of us with the older version is limited to those with bent or timed-out units. Mine, on a not-yet-flying airplane, is neither bent nor timed-out. Is it possible for us to get the $90 deal?
Jerre
Good question, thanks for asking. I am told that if you have the older model trim motor on an RV-12/12iS, you can contact Ray Allen Company and ask to arrange the exchange, regardless of condition or hours in service.
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
05-17-2020, 08:39 AM
Just as a matter of interest I'll post some pictures of three servos. These are all the original life limited servos.
Looks Ok ~580 hrs
Looks OK ~300 hrs
Looks bent ~800 hrs
Tony
E-LSA RV-12 ULS
05-17-2020, 09:15 AM
Tony -
Is servo with bent threaded rod yours? Any idea how it got bent? Manhandling stabilator or trim tab?
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
05-17-2020, 09:20 AM
Originally Posted by Tony_T
Just as a matter of interest I'll post some pictures ...
Looks bent ~800 hrs
Would be best to remove and further examine, and then send to Ray Allen for an exchange and so they can take a close look at it.
05-17-2020, 10:03 AM
Originally Posted by Piper J3
Tony -
Not mine. I do know the completed fuselage for this airplane was shipped across the country. The stab wasn't mounted but the servo and pushrod may have been. Could have been manhandled, but no way to know for sure. Otherwise, the airplane was always hangared and well maintained.
Yes, this one will be removed and sent to Ray Allen for review and replacement.
BTW, if your servo is like these with the rectangular actuator, you can slip a wire gauge like a spark plug gauge between the jam nut and the actuator which will help determine any bend. The gap is about .025 or a little wider.
Tony
E-LSA RV-12 ULS
05-17-2020, 10:10 AM
Thank you so much, Tony, for the the photos as examples.
2020 Dues paid
N72DJ, RV-12, bought flying. A Blessing in disguise. Thank you Double D!
05-23-2020, 12:42 PM
Have any of you tried to make this mod yet? Page 09, step 1 of the latest revision of KAI 11iS/U dated 5/12/20 has you adjust the rod end bearing so the pivot arm length is 16.0?. This dimension was 16-11/16? in the prior revision. The problem I?m having is that it is only 16? from the pivot point to the end of the F-1287F threaded insert for the rod end bearing. So there?s no way to achieve that dimension with the rod end bearing attached. And the part number for the AST push rod has not changed between revisions - still F-1287E.
What am I missing here?
And with about 18 hours on the hobbs, my threaded servo arm was ALREADY bent!!!
Anyone looked at this yet?
Bob Y - builder 12iS
N569TT first flight 2/9/2020
05-23-2020, 12:55 PM
Ok - per my previous post, I just noticed an inconsistency... The metric dimension shown is 42.39 cm, which is 16-11/16?. So, one is wrong. I?m guessing which one it is, but not sure why the 16-11/16? dimension was changed.
Scott, can you please confirm?
05-23-2020, 12:58 PM
We will check on that dimension when back in the office - thanks for the note.
Can you please send photos of your bent servo rod to support@vansaircraft.com? Would be interested in seeing yours. Thanks!
05-23-2020, 01:05 PM
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
